How long did your factory battery last?  Mine is a little over 5 years old. It's turning over hard. I know sitting for 6 weeks or more ,isn't helping. It's only been moved out and back in, just to get the mower out. Until we rearrange the garage. Being 5 years old probably makes the sitting worse. Should be used more now. Should be out of the wheelchair and walking again.
Putting it on a maintainer would help if it’s not used often. Glad to hear you’re going to be walking again!
Edited by Pryme
Im in.................................................................
I bought my 2024 in January of 2025, new. 3500 wt gasser, regular cab. My oem batt was replaced under warranty 3 months ago.
My mother got a chevy suv carryover the batt lasted 2 years and crapped out.
    What a crap show.... I called, said batt was bad 8 volts after charging for hours. OK, bring it in service department sais. Cant i just bring the battery in. Nope, we need to test it. How do you want me to get it 35 miles there? Buy another battery and bring it there, put oem batt back in so you can test it. We need to test it hear is all i got, in the vehicle.
     I went to napa and just got another one.
My 2015 ram 2500 diesel, the batts lasted 7 years and i only changed because i got a code for turbo actuator going out. I had heard new vehicles can do strange things with low voltage, so took a chance, even after load testing both batts, they tested good, changed them instead of the actuator.
   It turned out to be the actuator anyway.
Battery life has been decreasing over the last several years and this is supposition on my part but I'm going to wager that since flooded lead-acid cell batteries use recycled lead, that there has been a gradual contamination of said lead with non-ionic material over repeated recycling resulting in poorer performance and life cycle. I have no idea if there are currently any active lead mines in the US where pure new lead could be used in addition to the recycled lead to boost performance. I have 2 older AC-Delco group 78 batteries (one 9 years old, the other 10) that when sold had a 6 yr. warranty and an output of 800 CCA. The best that AC-Delco can offer in group 78 now has a 42 mo. warranty and 790 CCA. Both of my old batteries still function reliably in seldom driven vehicles with an occasional charge.
  • Haha 1
My trucks factory battery is still going strong with no signs of degradation. 2022. I do put it on a maintainer when I think about it.
Batteries are all over the charts. I was replacing a battery every two years in a car I drove once a month. I put a tender on it 5 years ago. Solved that problem. My wife’s Genesis first one lasted 4 years. Same brand, exact driving pattern. 10 years still going. The only reason I don’t replace it is, she’s never more than 10 minutes from me. My 02 avalanche same driving pattern 2 years, cheap auto zone battery.
10 years, 2 months, 29 days for Pepper. Factory installed battery is still in service. Battery Tender when left alone for more than a week. Sits most of the winter months but starts when I ask it to. Had is tested a few months ago after a nap where I didn't have the tender on it and was told...
THE KEEP ON TRUCKING Trademark of KEEP ON TRUCKING COMPANY, THE. Serial ...
Thanks all! I was driving it until a infection and I couldn't get my prosthetic leg on. I'm healed and should have it on tomorrow. But I have to get it on right away in morning. Or my leg starts to swell.
I had a 2022 gas truck that had the battery go down 7 months in from new, I'm in a another 22 diesel and it still has the original batteries.
I expect at least seven years from an OEM installed battery.
I have a 2017 Sierra 2500HD gas that was made November 16 2016, we got it the following week at the dealer I work at and it sat there until I bought it September 7 2017. It still has the original AGM battery and still going strong.
  • 5 months later...
I usually keep a tender on my vehicles and get 5-8+ years on them. Last several I bought the Duracell batteries at Sams and so far so good. FWIW, I had a Harley and got 11 years out of the battery, always on a tender when she was put up for the night.
I know about battery tenders. I have had one on motorcycle for years. The last battery lasted 9 years. I also have one on the running lawn mower. Batteries have lasted 5-6 years. I don't have one on the Silverado. I drive it, then I get laid up and can't drive. And it sits. I have left it sit for 4-5 weeks. So far it's always started. Sometimes it turned over hard, but always started. Then it's driven or let run for 15-30 minutes. The factory battery is 6 years old. Thinking that I may be on borrowed time.
With all the issues I have seen with some vehicles drawing down a battery if left sit for even a few weeks, never mind a few months as its stone dead by then, I already planned or should say was resigned to the fact that this 2025 is going to have an issue if left sitting for a while. Soon after I bought it I mounted up a tender under the hood that has the option to hard mount it into the system with eyelets on the 12 volt side of the charger, hooked the positive up to a spot in the fuseable box on top of the battery and the negative to a bracket bolt on the fender. I do have to pop the hood but have the cord protected with split loom to avoid vehicle use vibration damage to the cord and its end tucked away just behind the passenger headlight area when not being used. That is the good part about these trucks ironically that they don't have an underhood light that comes on to drain a battery, so if I figure I won't be using the truck for some days I will plug it in and its doing its thing and should help out some with cold weather starting since the battery should be topped up ready do do all it can.
I haven't left it sit for more than a week without using the tender but I experimented with checking the voltage on both batteries hours after it was parked and as the days went by the main battery was slowly loosing some voltage where as the secondary battery on the gas is isolated when the truck is not turned on electrically and it says up pretty much with no issue at the same time the main battery is trending down. The tender is only charging the main battery, it can't feed into the aux battery since the solenoid is not powered up that connects the two together.
If my truck is going to sit for 2 weeks or more, i have a solar panel and a solar controller that suction cups on the windshield. It's a 50W panel and I attach it to the vehicle via Anderson connectors.
My experience with  previous new vehicles is that they last 2 to 5 years. I think it all depends on how discharged the batteries have gotten while sitting around either before going into a vehicle or how long the vehicle has been sitting before sold. It's always interesting that the batteries in my new vehicles that last the longest are vehicles I special ordered. They sit around the least before being sold.
Edited by bruceb58
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
