Stiff Steering in Cold Weather
I live in New York and this morning the temp read 16 degrees in the truck. I noticed the steering was noticeably stiffer. Even after a 10 minute remote start and 15 minutes of driving it continued to feel this way. When I left work in the late afternoon is was 26 degrees and the steering felt the same as it did in the morning. I've lived in NY my whole life and never experienced this in any other car I've owned.
Being it's my first winter with my truck I have to ask-does anyone else experience this or is my issue completely unrelated to the weather?
  • Replies 32
It's weather. I noticed today on my truck, but I'm pretty sure every car gets a little stiff when that cold. My parking brake felt really weird this morning too..?
thank you! I thought it was just me...noticed it as well. went away after a few minutes of driving
It is normal, the truck has electric power steering (EPS) and this is a normal issue when the temps drop under 35°.
My 2014 feels really stiff in,the extreme cold too. I think it may be the nature of the 100% electric power steering.I assume since there is no pump that they probably use either grease or heavy oil in the steering gear instead of hydraulic fluid and hence would be more susceptible to extreme temps
Today it was around 30 degrees and the steering was back to normal. Thank you all for your replies-saved me a trip to a dealership.
Steering doesn't get stiff when using GM cold weather power steering fluid.
No power steering fluid in the 14+ models. There is no power steering pump as it's 100% electric
I live in Alaska and the coldest I've driven my truck in is -40 degrees. I have never experienced any stiff steering or braking. I'd probably get it checked out if i were you. And the average temperature i drive in is -10 to -20 in the winter time where I live and never experience it.
  • 11 months later...
Mine is very stiff, even to a point that it feels like manual steering. I have a 15 mile drive to work and it never gets easy to steer. Been 30 degrees or colder since I bought it so it may loosen up when it gets a little warmer.
I'm in NY too and notice no difference in steering due to temp. Maybe a slight difference if I'm in auto 4x but that could just be in my head.
I live in ND and was going to post about this same exact thing. I have a 16 Silverado z71 5.3 and the last couple days its been almost -20 F and the steering is really stiff. It gets better as it warms up. I chalked it up as "normal".
