saw on facebook Rough Country has released its leveling kit and 2.5" lift for the 2014. they look exactly the same as for the previous generation. But, they have a video that shows a new silverado with a 2.5" on it. although its a little low for me, it looks amazing
http://www.roughcountry.com/suspension/4wd-chevy/1500-leveling-lift-kit_1303.php
I like it! Is that basically the same lift/levelling kit as Traxda's(formerly Truxxx), and if yes, why is the RC lift levelling kit half the price?
So is it a 2.5" lift in the front and a 2" lift in the back, thus making it level? The website is confusing.
2.5 in front
Remove 1" stock lift block from rear and replace with 2"
Personally I would just want to level the front.
Sounds like the front need 1.5" of lift to level if you are leaving the rear stock. I wonder what tire would fit then? Probably not the size they list with their lift kit
Edited by 2009 GMC
If you just want to level the truck, no high lift, like I did, the Bilstein 5100s are the way to go. You retain complete shock and suspension travel as compared to other methods. Plus the great Bilstein ride. See the pdf from the bilstein site for a load of info on the other methods and their short comings. No damage to your suspension. Just saying...
http://www.bilsteinus.com/fileadmin/user_upload/user_upload_us/pdfs/Bil_LevShks_WebArticle.pdf
http://www.bilsteinus.com/products/truck-off-road/5100-series-ride-height-adjustable/
The first day on my 09 I put the Michelins on and then true and high speed balance on the truck. Them I added the Bilstein 5100s around which leveled the truck. Really made the ride and everyone that rides in my 09, CC, 4wdr z71 says the ride is the best they have seen in a truck (and they drive ford, GM and toy trks).
With the stiffer frame and heavier anti roll bars the new trks should really take to the setup.
^ i did the level shocks from bilstein, but they claim it retains all factory features, but you are still compressing the spring....
Stock tire
265 65 R18 = 31.6
With RC lift kit
285 70 R17 = 32.7"
I'm anxious to see one in general but definitely with a lift. Just hoping RC has got the angles right so this doesn't eat the hell out of ball joints. Maybe GM put better ball joints in these(doubtful). Looks really good though.
Sent from my Galaxy Nexus using Tapatalk 2
The RC truck in the video looked NIIIICE! I love the longer bed with the CC. I think next time I will just do a level and 33s and this video has me wanting it NOW!
I measured my truck and the rake is about. 3 1/4" I'm goin with rough country's 2.5 level kit didn't see it on thier site but called them and its $95 plus shipping and I think I'm gonna go with 305 55 20 on the stock all terrain 20's prolly nitro terra grapplers
Ah ic well I ordered my 2.5" leveling kit today and 295/60/20 Nitto terra grapplers they come to 33.94"
I'll add these ones I found off of Instagram -
(Rough Country level)
gm-lift-kit_1303-installed-1_zps2e4e88dd
7" FTS lift
1002798_10151535231462637_245565210_n_zp
Enjoy!
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
