Alright guys, I have gone thru a ton of pages trying to understand all of this... It's making my head spin. I have a '15 LTZ with the s*itty Halogen Projector headlights and they suck. What exactly do I need, to get more light and a brighter pure white light ( not the piss yellow ), I hate the blue colored light so I was thinking 5500k. If someone can tell me everything I need... my second question is exactly how hard is it to install? I'm sick of the crappy lights that should be WAY better than they are. Came to Lubbock tonight, and on the way to the hotel on the pitch dark highways, the light just ISN'T the way it needs to be. I'm sure this is simple stuff to understand, but as I have never done this I would appreciate a little help, maybe a little step by step.
You can order the complete kits from either The Retro Fit Source, TRS, or FastHeadlights. FastHeadlights post on this forum under the name of FastWS6TA. If you decide TRS they have the Silverado Elite Spec Kit
I'd suggest Diode Dynamics. Very impressed with their kit so far.. 35 watt 6k kit..
I second Diode Dynamics, running their kit without issue.
Well my FRX 3.0 retro fit kit came for my Silverado and about to do the install but must say it looks abit intimidating. I had a video showing how to do it but now I can't find it anywhere. Anyone have a link to it for the Silverado's?
Thanks man. Phil sent me a message with options on different choices and if I'm going to do it, I think maybe the FXR kit would be best. But many have great results with different options. Met a guy tonight while at the car wash and started talking about our trucks, differences etc. Took this pictures showing the Projectors my 2015 LTZ came with and the ugly yellow light which isn't bright enough, compared to his 2016 LT Projector's. Clearly in person showed how vastly improved and great the new lights are, I am aiming for that color of light and brightness for mine, it was perfect... I also need to figure out which ones to get for the High Beam and Fogs.
27131393666_f53a726d82_k.jpg2015 Left ( Mine ) to 2016 left by Josh Clark, on Flickr
Please help with my FRX install in my projector Silverado headlights. To me it looks like you need to install one of the brackets first with the studs upright but then I can't get the projector in.DSCN1686_zpso94c7f9h.jpgDSCN1685_zpsq8jsrld9.jpg
Is this right?
If you don't use your brights that much don't waste money there. Phil helped me match my fogs to my headlights and he nailed it (35 watt w/ 6500k). I wish I would have gone with the FXR kit from the start.
Is this right?
That is correct. The top spacer is simply a spacer as you will use the factory mounting holes. You will most likely only be able to get one screw in place on the top since you are doing the rear install method. One screw is totally fine. It will hold no problem. Sorry I wasn't on earlier to help.
Sent from my SM-N920V using Tapatalk
Hey that's ok we all have things to do I understand but thanks for replying now though. Question, see how I have the bolts through the spacer then with a nut? I did that to keep them there and so they would not spin as I'm tightening the other nut after it goes through the housing. Well that is where I was having problems, the bolts stuck up too far not allowing clearance but from the link posted about showing how to do it I guess you do NOT put nuts on them like I did but rather leave then loose and hang down thus allowing more clearance to maneuver the light into position. Right?
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
    • The average lifespan of automobiles on the road is increasing - here's why
    • Typically it is the Torque Converter, I have a 2.7L Trail Boss and between 25-65 MPH at 1300-1500 rpms under light throttle it has a shudder which I almost consider and bobble or a gargle sound. They replaced my TC but it did not help any, others say it has fixed their issues. It has been back twice now with no fix after.
