Well I feel dumb now. I just found out why I wasn't able to find the bulb for my truck. Turns out the Denali's have LED's and apparently you can't change them the dealership told me.
Why wouldn’t you be able to change them? It should be just the bulb that’s different.
That's what I thought. But buddy on the phone want very friendly/helpful too be quite honest. It was like I was catching him at a bar time and he just wanted of the phone lol.
He said it comes as one unit. That sounds like upselling to me. But before I had a chance to ask him he hung up on me haha
I think he just didn’t want to help you on this matter. The bulb should be different and that’s it. Unless the LEDs have a different housing all together. Maybe someone who has them will chime in and clear things up.
I just installed a set of the GTR Ultra 2 LED bulbs into my OEM projectors in my 2015 GMC Sierra.  install was less then 30 minutes but did need the PWM interface module to make them work.  So far, i'm pleased and at least now I can tell that the headlights on and I can see light on the road.  They are definitely not as bright as my buddy's 2018 GMC OEM lights FWIW.  I still have the HID kit from fastheadlights as well, just never got around to installing them and they have never been out of the box.
Well install the kit!
one of those mods that never gets old. Still love my headlights 2 years later.
I just installed LasFit D5S LED's in my 2016 Silverado. Not exactly a retrofit, but it improves the OEM headlights DRASTICALLY. Check out my install video and comparison shots at the end. These are pretty cool, they come with a custom dust cover with a built in fan. The LED driver on the bulb also has a fan, so the two fans combined keep the inside of the headlight temps cooler.
Edited by fondupot
I just installed Ultra2 led bulbs in my 2014 Silverado with projector headlights trouble is that they flicker and shut off. What is this PWM module and what is involved in the install. I like the lights when they work, any help would be welcomed.
It is a simple box that plugs in between the bulb and harness. Plug and play. Should have come with the bulbs. Contact the seller and see if they will send the modules to you for free. Mine have been flawless for almost five months now.
  • 6 months later...
On 3/19/2019 at 4:49 PM, catpartsman said:
The only thing I had to take apart was the air box. Granted my truck came with projectors so no need to tear much apart at all.
Does it hurt not to get the aftermarket projectors?  I'm looking to buy this setup
https://www.fastheadlights.com/mobile/product.aspx?ProductCode=buy_hid_kit&404;http://www.fastheadlights.com:80/product-p/buy_hid_kit.htm=
I just got a 2014 Silverado High Country that has factory projectors in it, but halogen lights are booboo.
On 12/2/2019 at 8:56 PM, SFry27 said:
I have not done the retrofit yet, but I did get the Hylux/morimoto standard kit in from FastHeadlights.
I really like the setup of the Hylux ballast. It's a little bulky but it has good wire lengths and is very easily mountable vs the morimoto. I really like that in the event of a part failure, troubleshooting is very easy instead of swapping part after part side to side. Well constructed and simple.
The Morimoto bulbs though, Jesus. Keep reading, this is important.
The bulbs fit well. The lengths were acceptable. The connectors though are another story. One side clipped right in, one side I had to depin and pull the terminal seals back, reseat them into the connector, make the connection then force the seals back in. One side had incorrect polarity, so I had to switch the pins On my original Morimoto bulbs, one was correct, one was not as well.
In closing, very happy with the Hylux setup but I will avidly do what I can to no longer have Morimoto products in this truck or any other vehicle I work on. You're paying extra for nice packaging and that's literally it.
I hope this is insightful!
Do you have any pics of the headlights?
I’d keep the factory projectors and just add the HID kit. Works just fine with no issues at all. You will be amazed at the difference.
I pulled the trigger on them.  The factory lights are a vast difference coming from a 19 Texas edition to 14 high country
a word of caution when putting hids in oem projectors, i did  this 4 years ago and in the last year i noticed that my lights just sucked. i just installed 2014/15 (style) Chevy Silverado Morimoto D2S 5.0 retrofit kit with Hylux Ballasts. when i removed the old projectors i noticed all the chrome in the light bowl had faded out and were not shiny chrome any more, which leads me to believe that the heat from the hids destroyed the chrome finish
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
