So i put my RC 2" level kit and Toyo 295/55/20's on this weekend. Install was simple, just like on my 2011. It definitely helps to have an extra set of hands when wedging that spacer in there. 295/55/20 are right at 33" and approx 12.3" wide. I have ZERO clearance issues. As a matter of fact you can EASILY run 305/55/20's all day long with no rubbing issues...and this was on my 2wd SLT. Kinda wish I got the 305's instead but oh well. Truck looks awesome and all it needs is an alignment. So far it drives better than my leveled 2011. I did have Nitto Trail Graps on that one and went with Toyo Open County MT this time.
EC19092E-C3C6-4ECD-8C7D-6502F7485E82-189
Edited by Saleenpowr
  • Like 13
More pics please lol. You're truck looks awesome man
Thanks. Here is one more from yesterday. Considering we're getting 8-10 inches of rain the next two days, I won't be taking any better pics soon. :)
BD5F81F7-F1BD-43F0-9D0C-74DDC1C096AD-171
  • Like 12
Anyone done just a RC level on the front and kept the stock tires? Any pics? Should be doing mine this week, not messing with the rear. Wondering how it will look. Plan on testing it out for a few days and see if I like it before I get it aligned.
Does the All Terrain Trucks need a different kit???
I thinking about doing this... but I would want the front end still slightly lower. I'm guessing a 1.5 or 2in would be right?
Any of you leveled guys notice a different in handling. Granted I still need to take my truck in to get the alignment done, but when driving, i did the ol "Nascar keep the wheels warm" swerve thing. It felt like the truck rolled very heavily side to side. Not tight at all. I'm hoping that's because it needs to get aligned.
Anytime you change the geometry of a truck (level kit, life, etc) you are going to change the ride, handling .... how much depends on how high you went. And the change is always generally for the worse.
Of course that goes without saying. I had my 2011 leveled and didn't notice this much of roll side to side. It's probably because it needs an alignment.
7473330315x65.jpg How will a leveling kit do with these factory 22" GM wheels with 285/45/R22's? I want a more aggressive off road tire that has more sidewall, but not sure what the best size would be for the 2" level lift. Any advice is appreciated!post-124428-0-50815600-1380244080_thumb.jpg
Edited by voltedge
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
