It's going to be all over the place. Diameter, width, tread, etc.. Someone with a 35 will take a much bigger hit than someone with 33s. The Raptor comes with 35s and gets 13 mpg. It's 13 mpg because of the tires not the engine. Put 31.5 tires on it and change the gearing and it'll probably do very well on mpg. I have 33x12.50x18 tires and my average over the entire life of 10,000 miles is right about 16 when you factor in the speedo error. That's all city, which includes the L.A. freeway system, a.k.a. "Tijuana Gran Prix". I'm in the 2-3 mpg loss. I'm guessing 35s are gonna be around 3-5 mpg loss or more.
OK Cool. I plan on going with a 33x10.8x18 or a 33x11.6x18 so mine shouldn't be as drastic of a drop in fuel mileage. Correct?
I'm guessing you'll loose 2-3, depending on how you drive and the specific tire and pressures you run.
I finally got my tires in from tire rack and my motofab 2" level blocks in that I picked up for 39.99 on amazon. got the blocks installed alone in a little under 2 hours last Wednesday night, and got the 275/70/18 general grabber at2's mounted and the truck aligned up Friday morning. Really happy with how everything turned out. Didn't think it would look lifted but its very notable. Much more than I expected. I like the firmer ride and it actually feels like a solid truck to me now. I also removed the front air dam and coated the wheels with plasti as protection for the winter.
Edited by ddanis60
  • Like 4
got any side shots of the truck after the plasti dip. i was thinking about doing that to my rims as well but wasnt sure how it would look. i like it on your truck though man. it came out nice!
It looks great if you do it right and take your time. many many light coats with time to dry in between. The wheels on my daily driver focus ST have been done for almost 2 years and 30k miles. every six months or so I do another two coats as needed and always remove wheels and use playing cards or index cards in the bead so that there is no overspray. I also do the barrel of the wheel so everything looks uniform and "normal". every week or two, I've found that interior cleaning spray or even tire gel.. anything oil based, works great to being back the deep black color and really keeps the finish looking nice. Many people cant believe that my wheels are plasti-dipped because the finish is so smooth and even.
I misread your post but the plasti info is there for anyone who needs it ha. I only have one other picture of my truck and its in my garage at an angle. Ill take a few side shots soon.
only thing about putting tire shine gels on them is sometimes the dip can get weakened by shining gels, or at least I noticed it on mine. I was wiping gel onto my tires once and the dip had been thined out around the outter most part of the rim and it ended up coming off when I wiped over it a bit! Just a heads up. However I have noticed that Armor All Outlast tire shine Glaze works much better. Doesn't mess with dip and it gives a great shine overall for the dip and tires. Also its not slick at all like tire shines are. Just saying!
There is a bit of running shown in this picture but I warmed the can by sitting it in some very warm water before spraying. I did it so that I could get a better coat since it was cold outside. It ended up spraying out 2-3 times faster due to the pressure in the warm can! But still came out great.
884305A9-3706-4400-9400-98AEE61ABD19_zps
Yours look great. I probably have 10 to 15 coats on my cars wheels and I don't use much to keep them looking nice so I've never noticed any weakening but thanks for the heads up. I also use the armor all tire gel but found the turtle ice interior spray works great. I also use it on my tires to keep them black but I don't use tire shine on the tires themself. I rub a little into the rubber to keep the tires moistened and black, but then wipe down to eliminate shine. Just my personal preference. Plasti has such a bed rep because so many people don't take the time to do a good job. Nice to see another set of great looking wheels.
Edited by ddanis60
Is everyone happy with their RC leveling kit or would u buy something else?
im removing my RC 2" leveling kit and replacing it with rancho quicklift loaded. It hops all over the place when pulling my trailer. Installing quicklift in 2 days and will be posting review on my other thread
Sent from my iPhone 6
using Tapatalk
using Tapatalk
I thought there weren't any quicklift loaded for the 2014s? I know the quicklift 7000mt is for the 2014 but according to their site they don't make a quicklift loaded for the 2014. Though their description is vague on the 7000mt. I guess it gives you 2" of lift in the front?
I'm waiting on Bilsteins before i make a move but keep us updated.
yes they have been available for a while. Gorancho.com. I have 2014 Silverado ltz Max trailering 4x4. I'm getting quicklift loaded in front and rs9000xl in rear
Well hell when using their search engine i was putting 2014 gmc and all that came up was the 7000MT, if the quicklift loaded fits the 2014 chevy LTZ 4WD it should very well fit the 2014 GMC SLT 4WD should it not?
Well guys here she is leveled and new skins. I haven't discovered anything rubbing and the ride is incredible over those crappy Goodyears that come from the factory. Leveling Kit was a $40 Ebay 2" level kit, Aluminum spacer. Also New Nitto Terra Grapplers, yes they are wide 305/60/18. The look is awesome compared to factory. Here are the images.
Got any questions just ask
Do you think there would be issues turning with the factor molded mud flaps with this set up? I am thinking on doing the same thing to my truck.looks very good
Love it. Whenever I see a silver truck with black wheels it makes me wish I got silver.
How are those general at's in snow? I like the price of those and I'd go with the same size you bought.
Edited by 14x4
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
