I've spent the last month looking at this forum and everything else online so I could to try to get the best information on what to do to my 2014 Silverado to level it. After all the research I went with the Bilstein adjustables and Hankook Dynapro 275/70/18. This is my first post so I'll do my best on the before and after pics. The ride is great and better than factory. It's winter and truck is dirty but I couldn't be happier with this set up.
What setting do you have the bilsteins set on?
I have them set on the top (highest) setting. It's supposed to be 1.8" on the 2014 model. The rear have no lift and are stock height.
I have had my RC 2.5" level on now for 8,000 miles and have had no issues. I love the way my truck sits. And it was extremely easy to install.
I'm thinking about getting the same on my 14' all-terrain, how long did it take you and did you need any speciality tools to help the process?
Thanks for posting there are very few pics of the bilsteins on the new models. I'm waiting for my rears then going to get them installed. Did it raise the front up exactly 1.8" Hell it almost looks like it's sitting nose high.
I have a 2015 Sierra Denali and I just put the 2.5" RC level kit on the front. I didn't add the rear block because it sits almost perfectly level now. The problem I have is that it rides like a dump truck now. The front is really tight and bouncy. It has been aligned professionally and everything but the ride is definitely worse than I had anticipated. Anyone else have this problem? The truck does have the factory 22" wheels and the side wall of the tire is pretty low profile but this has me thinking of taking it off completely. Any suggestions because Rough Country said they had never heard of this before?!
My husband and I just bought a 2015 Sierra Denali 2500 brand new a week ago. We previously had a 2012 Ford Lariat F-350. The Ford always had a rough ride and I hated it. We test drove the Denali and absolutely fell in love with the ride. My husband wanted the leveling kit put on it just because he didn't like the slight slant. We had it done and picked it up yesterday. The ride is now horrible (worse than the Ford was). Every little bump makes the front end bouncy. I have an appointment to have the leveling kit removed on Monday. Lesson learned. Read before I buy.
I haven't measured it yet, it may look nose high in the pic because of my driveway slant, it appears level on level ground, I wouldn't want the front any higher, depending on how it looks when I tow or have a load, I may add a small block in the rear to give it some rake. I have the long box crew cab. Not sure if that makes a diff but it would be nose high if the front came up any more. The Bilsteins gave the front all the lift it would take.
I too would like to change out the stock ranchos with the bilteins. I really dislike the ride after the 2inch RC spacer. I really need to get to around a 2.5 up front. Has anyone left the 2inch spacer on and mounted the bileins on the lowest or 1rst setting?
I say leave it a lone and drive it ! Enjoy man beautiful truck !!
Sent from my iPhone 6 using Tapatalk
Agreed.
I think the black handles/mirrors look good with the black wheels. X2 on black bowties.
It took me about 3.5 hours to do it by myself. No specialty tools needed, just some wrenches and sockets. If I had an extra set of hands it probably would have shaved off 45 min. or so.
Sounds good, have any of yall tried the rancho quicklift leveling shocks, similar to the bilsteins but it comes fully assembled with coil springs and everything. Bad part is its pretty pricey at $400
Take a side pic of your truck with that setup. Are they flush with the wheel well ? Did ya have to do any trimming for the 33x12.50-20 with 18 mm offset?
wow... long thread and now I am more confused than ever. I am looking for pics that are running stock 18's. I am looking at either a 2 or 2.25 in level with either 275 70 18 or 285 75 18 ...I only have a 4.3 so really don't want to go much bigger, just looking to level and get a little more clearance for hunting some back woods places. thanks
Me too.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
