34's did not require trimming, at least for me. See my signature block and photo gallery for more details. Smartest solution is to have your shop do a test fit before committing the $$, that's what Discount Tire did for me.
Thanks for the clarification. I've since decided to get 17" rims which will allow 285/70/17 or 295/70/17.
33x11.5x17 or 33.6x12x17. Either should fit. Funny 285/70/17 toyo Mts are 350$ RTs are 317$ and the 295/70/17 Mts are 318$. Weird.
All about what sizes are popular. If it's a more common size to be purchased it'll be cheaper. At one point I was looking at a 295/60/20 tire and it was like $60 more per tire than a 295/65/20
i run 285/75/17 and doesn't rub at all, i could probably even go to a 305/70/17 and be ok but i just got a 2.25 kit put on the front
Hey guys, I've read over all the pages and got a lot of good insight. Here is my plan to level my truck (2015 GMC Sierra 1500 Z71 Crew Cab Standard Bed.)
2.25 inch Ready Lift on the front
Blocks for the rear for an inch increase to keep some rake
I can't decide on what size tire to get...285/60R20 or 275/65R20, on factory 20s.
When I get this completed, I'll post pictures. Thanks for any input.
I'm looking at running 285/75r17's. What is the offset on your wheels? Got pics?
The only tire that comes in 285-60-20 is the Goodyear Duratrac. 275-65 opens your options up some and most mfg's make this size. In my opinion 285-60-20 is the perfect tire size and I am not sure why more manufacturers haven't caught on. I have no experience with the Duratrac but have heard great things. I have mine leveled and have Toyo Open Country AT2's on mine in the 275-60-20 which are too small in my opinion so I am looking at 295-55-20 or 275-65-20 as well.
Edited by hotrodz37
I agree 285/60/20 is perfect, but as you said noone makes it. So long 20s lol. Everyone has 17 sizes, Mickey Thompson, Toyo, Nitto, BFG, Goodyear, all of them almost have 285/70/17, actually i think all of them. I know not all have 295/70/17. 285/60/20 would work perfectly but if your wanting a 33" tire with no rub and are stuck to 295/55/20 or 305/55/20 you pretty much need spacers or a new rim for offset it seems. Which sucks.
It probably is stiffer but I don't notice. I think it handles better and you can actually put some weight in the rear without it sagging.
on my 2010 gmc all terrain 1500 I ran an add a leaf and a hellwig helper spring.
I'm on the fence on whether to go with a 2" block or adding a spring. I won't be doing it super often but I'll be carrying my 4 wheeler in the bed a few times over the summer. But when I'm not carrying the ATV, I'd like a smooth ride still.
Have you considered air bags? I know they won't affect the ride when they are deflated and can be adjusted. I don't tow often but when I do it pulls me way down so I plan to put airbags eventually.
Airbags sound expensive.
I'd want to keep it on the cheap side.
Airbags are cheap if you don't mind filling them manually. It's not quite as convenient but you get all the function.
I've read this whole thread and have gotten some great info, so thank you for that. My question is two-fold, I'm going to add a MotoFab 1.5" leveling kit to the front. My 2015 Silverado has the stock 17 inch wheels on it. With this leveling kit, and what are the largest size tires I can run with that leveling kit and keeping the stock 17 inch wheels? I've seen a lot of answers for the 18 inch wheel, just nothing for the 17 inch wheels.
Edited by Buckeye920
I run a 285-75-17 and it doesnt rub and that was without a level kit with a +12 offset wheel so i would say that this size would be the biggest IMHO. you would be safe really safe with a 285/70
I'll look into it
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
