I had mine installed for
Parts: $69
Labor: $125
Alignment: $109
Total: $303
Edited by ANazir
Question: I just received these today 20x9 with 0 offset 33/12.50 tires, and I don't get my RC2.5 level kit installed until Monday. This Friday I have an appointment at the dealership to have them road force balanced, and was wondering if I could get by the weekend with having the dealer throw them on for me. Would just be a little in town driving, and currently I have 22x9 +15 offset 305/45/22 tires and don't rub. Thanks
I would probably just wait until your kit gets installed and have them put the wheels & tires on. They're going to have to take the front wheels off anyways to put the lift on. Plus, you'll get the full effect all at once with the lift and tires!!
Take pics and share once you get it all completed, wheel/tire combo looks sick!
Edited by GooseCreekFarms
That's a good point! I'll just wait, thanks for the advice. I will put pics up Monday!
Cant do the install yourself. I did mine by myself with basic hand tools on the ground in about 2.5 hours its stupid simple. But ive done this stuff for years. Plus more complex builds and fab work but this is really straight forward.
Can i run a 295/55/20 on a 20x9 0 offset rim with just a RC 2" leveling kit?
Edited by SavageSierra
I've watched the videos on the install and would love to do it, and could probably do it if I took my time. I just don't have the equipment to jack the truck and stands etc. I like the idea of the dealership accessories dept. doing it in case there are any issues later as well.
Has anyone measured their roof line before and after installation of a 2"?
Stock 15 Sierra All terrain, I'm trying to see if I'll still be able to fit in the garage.
Edited by Nickyb
I have a 2.5 level and can still fit into the parking garage at work. 7' clearance I believe.
Same truck with 2.5" leveling kit and single add-a-leaf:
attachicon.gifImageUploadedByTapatalk1431579154.380615.jpgattachicon.gifImageUploadedByTapatalk1431579169.759214.jpg
Still have a Zone 1.5" body lift for it too, haven't decided for sure if I want to put it on or not.
This looks really good! Could you please tell me what brand of levelling kit you used and also the brand of add a leaf? Is this all that has been done to the truck?
Thanks
Thanks
Thanks, It has 275/60/20 BFG KO2's and I used a Top Gun Customz 2.5" leveling kit and a Zone add-a-leaf with the standard block.
I have since added a 1.5" body lift from Zone and 1.75" wheel spacers. If you do the leaf get some with the rubber pads on each end so they don't squeak, mine don't have them and they squeak. I can't hear it with the windows up but notice it at low speed with windows down.
I have a thread on the 'Vehicle Builds' section of the forum that at has similar pics at each mod.
2016 LTZ 4x4 with RC 2.5, Moto Metal 970 9x20 with a 0 offset, TOYO Open Country 305/55r20
Same setup as my 15 but wanted to get the new features and loved the 16 look!
Beautiful! Could you please upload a straight side view?
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
