Me too. I hate to see the uninformed getting bad information from these forums and spending more money than is needed for a 2.5" level. Also silly is the debate about plastic versus aluminum spacers. I could almost agree about putting UCAs due to the extreme angles from a level, but I have yet to see anyone post that their stock ball joints are wearing out at 50K miles....and there are tons of leveled 2014s getting up there in mileage. And new UCAs are $800 plus install plus alignment....so you might as well let the stockers wear out first.
Exactly. Even so though as long as you spray silicone on your cv boots so they don't dry and tear and don't go on trail rides every day they will last plenty long, might have to replace ball joints at 50K miles vs 80K with a stock set up. Not a big deal to me. At that point I'll stick new UCAs on and it'll be good for a long time.
Yeah that composite material used in level and spacer kits honestly is better. It's less money, more durable, can't corrode, absorbs shocks and impact a bit better. There's only benefit to it, but hey it's their money. They'll find out when they crank a strut at its maximum height and get 1.7 inches of lift it will ride like shit.
Plus half the time they over look that they stuck an aggressive 10 ply E rated tire on the truck. That alone will make your ride more rough than any spacer lol
Sent from my treestand using Tapatalk
You can run a spindle lift. CST suspension has them.
Socal Supertrucks has been installing quite a few on 2wd trucks.
Well talked with Socal today and they are changing lower arms on New trucks with the 2piece steel arms, to the older lower steel cast and replacing upper arms to make a Spindle CST spindle lift to work.....FYI
Not believing everything I hear or read it is my understanding the Bilsteins are a better shock (better ride) than the Ranchos. I just replaced my rears yesterday with 5100's and the ride it noticeably better.
My truck had a 2" level and I added the top spacer to get that ever so important (sarcasism) 1/2" extra and the ride suffered to me. I'm going to go back to the Bilsteins ( 2012 F-150) for a better ride and have talked with other forum members and read that that ride is better. I'm no longer worried about that 1/2" which I believe worsened my ride.
I am the first to admit my knowledge on this is minimal but that's why come on here to hopefully teach my old ass something and just check out what others are doing.
Peace out!!
Edited by mmwest
All of these arguments are good and make complete sense to me. However, I have yet to hear from someone who doesn't like their bilsteins. Is anyone out there?
I had 100k KM (~60k miles) on my '14 double cab with LTs from day one and didn't have any wear shown when I sold it. GM inspected and passed - only thing was needed was some rear brake pads which was impressive enough. I agree the 2" has little to no impact for a daily driver...
Thinking of picking up a 2.5" RC kit and was wanting to run RBP HK-5 20x9 wheels. Any suggestions as far tire size looking at Toyo or Nitto Terra Grapplers. For some reason I have always liked the look of tires sticking out just a bit past the fender and saw someone with 20x9 with +14 offset with 320/50 and they stuck out about 1" outside the fender, he was also running the 2.5" RC kit.
Just and update down about 2 MPG with RC 2.5 level and 305/55/20 toyo xtremes 10 plys. You do notice the power to weight ratio but man I love the look, ride, ride height. You don't buy a truck like this if your worried about mpg. My wife drives a Nissan Altima 4 banger what she saves i'll burn.
Ok so I have tapatalk now and don't like it but it is what it is. Here is my 2016 Silverado LT-Z71. It doesn't have all the technology like my old Dodge Charger rt Max AWD but it can haul my dirtbike and I love everything about it. I plan on putting a 2.25" level on the front. Those stock 22" wheels and the tires make for an already bumpy ride but I could care less. I like bouncing around and I like em loud. I currently have the tonneau soft cover, window shades, tinted windows, side steps,'black emblems, front good clear protectant film, line-x bed, spintech 6000 single in single out muffler in stock location, and my favorite mod of all is my QTP electronic cutout. It makes it roar. In V4 mode it sounds like a Harley Davidson, and shakes my teeth out of my face. Best mod ever!!!!!
c4aa29bd2b153abf50c33e125628e37e.jpgb55c33a70ab9ef3d1057ac5c690fa63e.jpge8e2bdceb9222333c782e429cf44125e.jpghttps://vimeo.com/178796578 that is the spintech 6000 at idle and revving
This next video is the cutout open https://vimeo.com/178796661
If anyone has any questions just let me know.
Anybody running a 305-55-20 on a 20x10 -24? With 2.5 in level
Sent from my XT1254 using Tapatalk
Videos won't load. Are the 6000 series obnoxious loud or just enough. Would you compare it to a fm 10 or 40?
Sent from my Nexus 6P using Tapatalk
I know this has been beat to death. I have a 2016 Silverado with a 2 1/4" front level only. Looking at All Terrain rims 20x9 +27mm offset, replicas. Mounted on BF Goodrich K02's 275/65/20.
Im assuming no rubbing or maybe a slight potential on full lock turn in the front. Also is it a better bet to go with 275/60's
Need to be more assured before i pull the trigger
The spintech 6000 was actually much more quiet than I anticipated. Then again I only have one in one out, but not loud enough for me. The tone is second to none. It sounds the best out of any I've heard. I am used to flowmaster original 40's. I liked the drone and the volume. The spintech 6000 seems about 25% more quiet and that's taking into consideration that it's only a single and my flowmasters were all duals. Overall it's a great sound but I wanted ridiculousness so I added the QTP cutout and now she screams at the push of a switch. I've got the best of both worlds.
If anyone wants to hear the spintech 6000 or the qtp cutout and the videos won't loud I can't email them to you. Just let me know
A quick side note...... Either I was still half asleep or having a wet road with my cutout open made it 50% louder than when it's dry. I am an audio engineer by trade so it does make sense that the water on the road fills in the gaps in the concrete or asphalt creating a more flat surface for the sound to reflect evenly. Call me crazy but it definetly woke me up pretty good. God I love that thing!!
Edited by Houseopayne
Since it was time for new tires figured it was time to put on the level too.
Readylift 2.25"
285/70/17 Toyo Open Country AT2
Readylift 2.25"
Nice combination! I am considering a similar setup. Is the difference in handling or gas mileage significant?
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
