Sharp looking rig! What are you running up front? And may just be the angle, but anything in the rear?
Sorry meant to quote you.
2" level in the front +1" block in the rear. 275/65-20 (34") tires.
Rough Country 2.5" and 35x11.50 Nitto Ridge Grapplers
Yup! Made my new setup pretty easy to decide on.
My thoughts as well.
Considering these are bigger than a 285/65/20, and everyone says those rub, I just don't see how it's feasible without some rub.
Well the air dam is removed so that helps, but it looks like he has positive offset, so that hurts. I would say that it does rub somewhere. Probably on the rear inside of the front wheel liner.
Just got my leveling kit in last night!! Cant wait till I install them over the weekend!!
I decided to go with the 2.5" kit
OK, I'll bite. Where do they rub?
it rubs the sway bar at full lock. I cut the inner fender liner so there is no rub there
Edited by THE_Engineer
anybody got picture with a 2in front and rear with stock tire size... im buying the rc 2.5 kit but i think it would look weird with stock tire at 2.5 so im thinking going with the 2in f/r like my old truck was
This is a 2" front w/ factory tires. I don't think another .5" would look that bad. when time for tires just go up to a 33
you got the 2in at the back too??... i wont put tire on for a while since i got ko2 with the truck
No, just the fronts. Thought it would give you some idea of what it would look l like. My wranglers have 23K and about 10K left. cant wait to upgrade tires.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
