Running the 2.25" Readylift leveling kit up front, has the upper and lower spacer. Also added the 1" taller block out back. Only about 5k miles on the setup so far but no issues and rides fairly well in my opinion. Tires are 305/55/20 on 20x10, -24 wheels. I did have to trim some plastic and zip tie the fender liner back, still rubs in reverse while turning but nothing serious.
8c03cee41c4bffcddd69ef4196f317cb.jpg4fb3cd23452908a493f2c8462ae10522.jpgbee623a58c57fc8bf0244327acaf6bbd.jpgcf39a752a9404ed972218ea0cca0d439.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
On 12/27/2017 at 4:07 PM, steve76t said:
Leveled!  Rough Country 2" Magride level kit with 285/55R20 BFG KO2 tires.
What is the rake on this if you do t mind me asking? 1 1/2”?
12 hours ago, JSB81 said:
I have a 2018 Seirra Denali 1500 with a 6.2 and added a RC 2.5” leveling kit. With leveling kit in and when 4 wheel drive engaged it have a pretty good vibration when engine is under a load. Anyone else have this? Take leveling kit out and it goes away.
Sounds like your u joints are out of phase.  Is ur rear block installed?  Some guys leave out the rear block.  U could experiment like that or I'd get ahold of rough country and straigten it out.
Also make sure it's compatible with magneride
Edited by Tyy1907
We actually took rear block out and put 2” in the front. Didn’t make a difference. Also put spacers and dropped deferential. Nothing changed.
That's odd. I had no issue. Did you have the dealer "re-zero" the magnaride? basically after you do the level the magnaride thinks its in a giant perpetual bump and will ride like a dump truck until you do this.
Yes they did. I’m sure it’s one of those crappy luck deals. Put the 2” kit in a 5.3 Denali and all the problems went away ??‍♂️
Yup, almost 1 1/2" exactly.  It's 1 3/8" on the drivers side and 1 1/2" on the passenger.
Looks great!  With regards to the ReadyLift...do you have the option to only put in the top round spacer and leave the bottom U spacer out or do you have to install both?  Also do you happen to know how much of a lift you would get by just putting in the top or bottom spacer?
Thank you. You could leave one or the other out. I believe the upper spacer raises it 1.5" and the lower gets you the other 3/4" but I'm not for sure on that.
On 2/17/2018 at 3:24 PM, 6.2_GMC_DEN said:
Installed 5100 Bilsteins with 2" Level and 305/55R20 Nitto Terra Grappler G2. The ride is better than Stock which was really good, this thing is super smooth and quiet quiet quiet! I also added 8mm spacers to ensure no rub and I did not have to trim anything. One thing I think folks need to consider is doing a performance balance on their tires and I am absolutely not talking about Roadforce. We took Static down to under .05oz and Dynamic to under .10oz a tire and this thing rides like butter. I am super happy with this set-up!
Can you elaborate on the "performance balance?"  I have the same tires (XL rated).  Could only get the road force balance down to 16 & 19 lbs. on two of the tires and it is evident at highway speeds.
Installed a 3" Motofab level on my 2016 Silverado Z71 last weekend. Rear is stock. Wheels are 20x12 -44 offset and tires are 33x12.5. Took some plastic and metal trimming, no rub at full turn. Before and after pics below. Smoking my turn signals and corner markers this weekend.. will probably vinyl wrap the chrome bumper mustache too.
That is a great looking truck! How are you liking the Atturo's so far?
Loving them so far. Only have about 400 miles on them. They growl a bit at low speeds and hum over 50+, but I actually like hearing them. Nothing overwhelming. Very smooth for a mud tire. My little brother has them on his 2009 and they're wearing very nice.
Good question.
First question would be do you feel steering wheel shimmy (side to side vibration or Couple vibration) or do you feel in your seat or dash area a hopping sensation (up and down vibration or Static vibration)?
My performance balance method is done by mounting the wheel correctly with low taper collet on back side of wheel and using a pin plate to secure wheel by the lugs. I then put my direct drive COATS Balancer in "fine mode" (opens blind under .25oz) and remove all residual unbalance to under .10oz. In most cases I get it to .03 to .01oz where a Hunter Balancer will only go down to .10oz. If these unbalance forces line up you could still potentially have .20oz residual on this Balancer. This is stated in the GM bulletin to take a Hunter Balancer out of "Smartweight mode". FYI Smartweight mode is a marketing term used to sell a shop on money they can save on wheel weight purchases without sacrificing Balancer quality. Unfortunately in the real world there are too many variables and the shop can potentially leave themselves open to come backs.
The Roadforce you mention with 16 and 19 lbs means there is run-out of .016" and .019" of an inch in the tire & wheel assembly. You can actually tell if you have a problem if you have a High Static number when you Balance. If run-out number creeps over 30 or Static number over 3oz then you could potentially feel that, especially if you combine it with a Smartweight balance.
Eliminating all vibrations (Static & Couple) is the best practice for best results. You can really feel a difference.
I got the "balance beads" with my new setup, no weights, smooth as glass.
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
    • Forgot to mention that this started after changing the oil I use mobile 1 full syn with mobile one filter but I did add pro lube additive and was the first time doing so and is making me wonder just can't see why that would matter
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
