23 hours ago, EDL said:
Are you guys that are adding the 2" to 2.5" leveling kits also adding a diff drop?
No need for a diff drop to do a 2-2.5" level.
Ok, thanks, was just curious.  I did some reading and watched some videos of the installs and in many cases they still recommended a diff drop just to try and keep the CV angles as close to stock as possible.  Heck, from the videos, the drops were only spacers and not terribly difficult to install.
I learned the hard way many years ago about drive shafts, drive angles, u-joints and such when I used to jack my trucks to stupid levels, so maybe I'm just being too sensitive :-)
On 6/13/2018 at 6:45 PM, dougwtx said:
2018 GMC 1500 Crew Cab SLT with 3.5" Superlift kit.
this looks perfect to me (height-wise). how are you liking the lift so far? How does it do on the highway? Looks awesome!
Thanks!  It rides great.  90% is highway use.  It rides just a tad stiffer than stock.  It does have the Superlift shocks in rear that came with the kit and a Hellwig 7886 rear anti-sway bar was added.
perfect thank you!! Seems like the 18's are gonna have to get a new UCA's regardless of what you want to run. I wouldn't mind getting rid of the ranchos all together and getting bilsteins all around (with the superlift UCA's) or something. Eitherway, looks awesome!!
I'm still undecided which way to go. I'm leaning towards the RC 2", but has anyone installed the Rancho Loaded quickLIFT strut assemblies? It gives you 2" up front plus 9 position adjustable shocks and struts.
This looks really nice. Installed yourself? From what I read in the Superlift site, it comes with spacers for the diff too so the diff does drop down slightly, right? Stock front shocks?
Edited by '17 Sierra
Thanks!  I had a shop do the installation.  Yes, it comes with spacers to drop the diff.  Front shocks are factory.
2.5 RC Level on 34's (she needs a bath)
What’s the actual tire specs? Factory wheels are you running spacers?
the actual specs say 33.8" so were rounding up here. it rubs at full lock both forward and reverse so im looking into 2" spacers until I can find a set of wheels I like
It looks good I want to level mine and leave the factory wheels and run spacers and a bigger more aggressive tire. What is the actual size (example 295/55/20) that’s what I was looking for
285/60/20 I like a wider tire rather than taller. I know some people on here run a 275/65/20 which is the stock width and just beefier. im not a fan of chevy's big wheel wells, cant fit a big tire in there to close the gap with out doing some mods.
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
