IMHO, Because I’ve had both on the same truck. The Ridge Grapplers are much more rugged looking than the KO2’s, very much make the look of the truck. The KO2’s seem to have a bit softer ride to them versus the Ridge Grapplers. Another thing is that the Ridge Grapplers are bigger tires and will take up a bit more room, 1/4”.
My experience with the Ridge Grapplers, over curbs, curb rashes, zero sign of anything. The KO2’s will show everything. That’s why I’m thinking they’re of a softer compound.
I had the KO2’s on for a few days before returning them due to vibrations at high speeds. KO2’s are well known to have some of those issues in the Jeep forums.
I went with the 285/65r18 ridge grapplers and 2” level. Will be in the shop on Monday. Ridge graps were cheaper too!
Are you running stock wheels? If you are, be prepared for serious rubbing. I had to buy new wheels with +1 offset. In a couple of weeks it’ll be lifted. [emoji6]
He has 18" rims, not 20". 285/65r18 fit fine with 2" level
My bad
Anything smaller than a20” is smaller, sorta wish I went with 18” wheels mostly cause you can find C rated or D but once you get a level or lift, starting with a 20” you’ll start heading into the E and F rated tires. 285/60/20 Nitto Ridge Grappler is close to $400 each, installed with warranty.
On 11/1/2018 at 2:25 PM, Bushleaguechew said:
How’s the rubbing? I tried that wheel and tire combo at 3” of lift and it was hitting the cab mount behind the fender liner.
Honestly, I don't rub that bad at all. The only rubbing issues I have are at full lock and even at that the tire just barely rubs the carpet fender liner. And I mean just barely touches it. I had ordered a 1.5" body lift that I thought I would need to clear the tires but they fit just fine without it. I take it off road every once in awhile and it does fine. I think it comes down to the offset I guess. I have +18 offset.
For those of you who have a 2017+ and installed 2.25" level without changing the UCAs, have you had any issues. Dealer is offering to install a ProComp kit without UCAs and keep my warranty in tact but I don't want to make the truck unsafe even if they keep the warranty. What good is a warranty if the truck is totaled?
On 11/2/2018 at 1:32 PM, ShubiSnax said:
275/60/r20 Duratracs
I dig it. Any rub with this setup? Are you running stock UCA? Is that a 1.5" level? Thanks
Running a procomp lift will included diff drop which doesn’t need new UCA’s cause with a diff drop your UCA’s will be fine for a while.
You should look at CST suspension, much better quality and doesn’t make your track widen up front like it does with all those knuckle replacement kits such as BDS, ProComp. A couple guy on this forum brought it up and I jumped on it.
Sent from above
Running a procomp loft will included diff drop which doesn’t need new UCA’s cause with a diff drop your UCA’s will be fine for a while.
Sent from above
The procomp is just a 1.5" top spacer and .75" spacer on the bottom. Just a regular level
That’s exactly what I’ve got but I immediately noticed right after I bought it and leveled it with stock tires then the headache started, bigger tires rubbed causing me to spend $3K on new wheels and tires. I’m looking forward to the lift cause apparently it’s going to ride like stock again.
Sent from above
Just dropped the truck off. Here’s the before 40bff0a952a20ccaaa2be7bcccd88916.jpg
What are you having done?
Sent from above
I have a 2017 and have the ProComp 2.25" level. I ran it with the stock UCAs for about 20k miles without any issues. I got my 2017 in August of 2016 and none of the levels were offering replacement UCAs. I added cognito UCAs because I got them used for a good price. I'm not saying you wont have any issues but I'm not easy on my truck and the ball joints were fine when I took the stock UCAs out.
The ProComp kit is just a level and doesn't include a diff drop. It is the exact same kit as the Readylift 2.25" level just in a different box and costs less. Now Readylift is offering replacement UCAs with the kit. 7fdd87731ce40372b9d3b6d7ad7fbf8b.jpg
Sent from my SM-G950U using Tapatalk
    Brandon 29
    Brandon 29
  • Who's Online   0 Members, 0 Anonymous, 365 Guests (See full list)
