So my first problem with my set-up. My driver side tire rubs UCA when turned to right at full cock. Left side fine. Ordered 1/4" spacers for now. My local shop guy told me running stock wheels with aftermarket UCA causes the rub sometimes?
Anyone????
Well had to do it. Stock wheels wouldnt stop rubbing at full cock to the right with new Freedom UCA's. Bought some KX offroad (makers of XD) 18x9 with -12 offset wrapped in 265/65-r18 Falken Wildpeak AT3. 33x12.5r18 dont fit. I get the rub on rear fender well and im not cutting or banging my new truck. Ill wear these out then raise my truck another inch and try for 33's next time. Gonna install some lighting next.aaed7a2bcb41944d59cb532e98dd271b.jpg6b6caf92f3e7f53edb905f2b845052af.jpg47db913f3200cf5dca3aff0fdf47d23b.jpg
On 9/3/2019 at 1:24 PM, alodawg26 said:
Hello All. I have been searching for a few days now, but haven't found exactly what I'm trying to do. I have a stock suspension 2017 Silverado z71. I'm looking to level it out and improve the ride, but still want a small amount of rake for when I tow/haul. This is my daily driver, and don't do a lot of off-road driving. Most of my driving will be on the highway in the Midwest, meaning horribly maintained asphalt. I'm considering:
Bilstein 5100 adjustable on the next to highest (3rd?) setting OR, do I want to do a coilover assembly replacement? I haven't seen anything on these yet: https://www.roughcountry.com/gm-leveling-struts-500063.html?find=2017-chevy-silverado-1500-4wd-374174. Has anyone installed/used these? If so, how is the ride quality of these?? I've seen nothing on the N3 shocks. $329 seems pretty cheap especially when comparing against the Fox and Bilstein 6112. If I go the coilover and shock replacement route, should I just save my money and buy a Bilstein or Fox?
Thanks for your help and advice.
What did you wind up going with?
Anyone????
Hate to hear that.  Unfortunately, it’s what I’ve heard a lot of.  Did you get the rub  before or after the new tires?  I’m told anything over 11.5” wide will rub with the factory wheels.  Wondering if I stayed at 11” if they’d still do it. If you did get the rub before new tires, what did you have on it previously? On a side note for anyone interested, I talked to JBA Offroad today inquiring about their arms.  For now, they make nothing compatible with the stamped steel or aluminum UCAs, only the cast steel,  but they are in the works.   However, he couldn’t tell me an expected release date.  If you look at the design of their arms, they are built with a slight bend in them he said that corrects this issue everyone’s having with rubbing.  Too bad they aren’t available yet?.  At any rate, doesn’t do us much good for now, but hopefully they’ll get them out sooner than later.
Hate to hear that.  Unfortunately, it’s what I’ve heard a lot of.  Did you get the rub  before or after the new tires?  I’m told anything over 11.5” wide will rub with the factory wheels.  Wondering if I stayed at 11” if they’d still do it. If you did get the rub before new tires, what did you have on it previously? On a side note for anyone interested, I talked to JBA Offroad today inquiring about their arms.  For now, they make nothing compatible with the stamped steel or aluminum UCAs, only the cast steel,  but they are in the works.   However, he couldn’t tell me an expected release date.  If you look at the design of their arms, they are built with a slight bend in them he said that corrects this issue everyone’s having with rubbing.  Too bad they aren’t available yet[emoji57].  At any rate, doesn’t do us much good for now, but hopefully they’ll get them out sooner than later.
Was getting the rub with stock wheels and tires. Went with18x9 -12 offset wheels and 275x65r18 tires...no rub anymore. 32.3" tall and 11" wide.
Sent from my SM-T580 using Tapatalk
Anyone on here ever tried 285/70/18 tires with a 2" rough country level on a 2014 chevy Silverado? My 275/70/18 toyo open country m/t's have 55k miles on them and its time for a new set. I'm tempted to try the 285/70/18 in nitto ridge grappler. Anyone have this set up? If so, any rub and how much? Attached is a pic of my truck with the 275/70/18 toyo open country m/t (33.6 x 11) with no rub.
I have a 2" RC level and 285/70/18's on stock rims and there has been no issues thus far (a little over 3k miles since everything was installed).  My truck is a 2018 2500HD though so it's not apples-to-apples.
I wouldn't expect them to rub on a 2500. Thanks for the comment though!
Was told that size is hard to get.
In nitto ridge grapplers?
Guys run 295/70/17s so dont see how that size would rub if those dont
I'm gonna try it and see. It still blows my mind I've yet to find one single person with the exact setup I'm asking about. Maybe ill be the first with a 2" RC level and 285/70/18 nitto ridge grapplers lol
I’ve never even heard of that size before. That being said, they’re very similar to a 285/75/17 and those will for sure rub on a 2” level. It will require some trimming but it’s doable
Just that size in general. I wanted that size. Told i had to wait to get. I dunno didnt want to wait.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 409 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
