2 hours ago, Sierra Jon said:
That looks awesome. What brand kit and size tires did you go with?
Sent from my Pixel 4 XL using Tapatalk
I went with the 2.25in readylift kit with the upper control arms and 33x12.5r22 nitto ridge grapplers. Looks way better in person I just suck at taking pictures
Lol thanks. It looks perfect dude seriously.
I really didn't want to go load e tires because of the weight so I'm contemplating either staying with the same size tire or downsizing to 20".
First world problems...
Nitto ridge grapplers are load f 12ply
I think you can get them in both but you see my dilemma. You notice a huge difference?
4 hours ago, jimbrown1 said:
RC shocks are terrible, I wouldn't even consider them.  If you plan to tow, consider replacing the rear blocks with something a little taller to keep some rake from rear to front so the back won't squat and be lower than the front when you tow.
Good to know, any recommendations for rear blocks ?
4 hours ago, Sierra Jon said:
I would suggest going Bilstein 5100 all the way around. You'll have 0-1.8" adjustability up front and 0-1" in the back... I'd run the front on the highest setting and leave the back at normal ride height. You'd be able to maintain a little bit of rake for towing.
If I didn't have magneride that's what I would do.
Excellent, that makes sense. Where’s the best place to purchase Bilsteins ?
Bilstien's are great...but another option is Eibach...they are american made and also have a package that comes with front springs (Pro Truck)...worth some research...
On 7/18/2020 at 7:25 AM, Sierra Jon said:
Any other Denali owners running the Zone 2" leveling kit? I see good reviews on the composite spacer but was hoping to hear first hand.
Also how's the magneride after install of relocation bracket? I'm concerned there is no magneride recalibration necessary...
I love the magneride but it's been an expensive obstacle for a simple level kit...
Thanks,
Jon
I've got a Denali and installed the X-ineering Magneride bypass kit so I could go with an entirely new suspension (http://shocksims.com/#top). It's a super easy plug and play kit where I've had ZERO issues outside of the initial install. Their customer support is outstanding and they will help troubleshoot any issues when first installing (I had to do a recalibration of the suspension module and they sent me the tool to do it free of charge). After an initial tweak I have had no codes or issues since. Installed the Halolifts complete kit and love the stance and ride.
Thanks for the info man I appreciate it. I haven't committed to ditching magneride. I do think it is an amazing ride - way better than my stock '14 K2. Boston roads are terrible too.
The two road blocks I've had since magneride are helper springs and now the level kit.
I think I've convinced myself the zone is sufficient but wanted to hear from someone who has it.
Yeah sorry I can't speak to the Zone 2" level. Figured letting you know you can get around the magneride system was at least worth passing along. For what it's worth, with my Halolifts adjustable kit I went with a 2.5" lift in the front and 1" in the rear, mostly leveled it out but kept a rake for when I tow. I kept the stock UCA's on and have had no issues. Although I did cut out the UCA stops that are welded just beneath the UCA. I don't do any serious off-roading so I'm not worried about the UCA traveling too far and causing damage, but figured I better cut the stop out for the occasional trail runs I do when camping. In the crazy off chance it happens I'll just go with an aftermarket UCA at that time. Good luck finding the set up you want.
Got sick of the crappy Rancho ride, through a lot of reading and researching, I decided to go with FOX extended length 2.5's and the cognito UCA. After a week from ordering, I was called and told the Fox won't be manufactured until September. I was offered a set of King's for cost and they were in stock, couldn't pass on that. Finally got them all installed last Friday and alignment done yesterday. Before this, I had a 2" top spacer with a ride height of 23.5" ( center of hub to fender) and now I lost only .5 with a stock setting on the shock. It looks ok to me, and I can live with the 1/2 inch till I need new tires and then I will crank it up a little. My rims are stock 20's and the tires are BFG KO 275 65 20. My does this truck drive nice on the road and off.
Edited by tjrado
Added pic
Hey guys, I'm new to the Silverado life here and have a specific question. My 2017 1500 LT came to me with 275/55r20 tires, no other mods. I am looking to put on a 2" leveling kit next weekend. Will 285/60r20 tires fit? Searching for a specific answer for hours has yielded no results.
(I'm looking at the Grabbers so they're 33.5" diam.)
On 7/14/2020 at 7:30 AM, Vdravin said:
3 in motofab
Was this the kit with UCA also?
i went with the 2" in the front and the measurements are spot on for fenders but still looks like som squat.
Does anyone make a 1/2" blockor is the smallest available a 1"?
im tempted to go down to a 1.5 front but love the way the front end sits.
I'm curious about this as well. My truck sits perfectly level with a 2" kit up front. But on uneven ground or with any load in the back I get some squat. I added Hellwig 990 helper springs, and they definitely improved the ride with a load, but didn't get rid of the squat like I expected.
I was toying with the idea of going .5 or 1 inch higher with a block in the back. Didn't see any blocks for a .5 inch lift though...
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
