Have you installed you catch can yet? I'm really interested because its a plug and play. What's it going to cost you? How long will the hoses end up being?
Hey sorry for the delay, I am hoping to have it in by next week. Cost is going to be ~$200 and hose length provided will depend your motor. V6 and V8 5.3 will be a few feet more than the V8 6.2 due to the location of the intake manifold inlet.
Edited by bladz1454
Just drained my RC Catch can on my 5.3l engine after 700 miles. It's been unusually cold here in the North East which may explain why the oil looks like coffee!
What appears to be bubbles in the photo is actually texture on the measuring glass I used. I need to find a better glass (steal something from the wife's kitchen maybe) :idiot:
Looks to be a little over an ounce.
First time draining my RX catch can. This 571 miles. Did now just because the measuring glass I ordered for came in today.52d47908e905ccbeee30d6390c31a393.jpg
My RX can arrived today (5.3) and I just put it in. It only took a week and a half to get here and everything seems satisfactory so far.
What are you guys doing with your drain tube? Sorry if I missed any explanation on that. It almost seems unneeded because I could fit a small cup under the drain valve.
Also, they gave me a ziplock bag full of barbed fittings and I don't need any of them. Am I missing something? I assume they're given just in case.
Lastly, just to be clear, no body cut apart the stock hose and reused those quick-connect fittings with the new hose, right? Everyone just put the new, given hose right up to the smooth male fittings off the engine?
Edited by 14x4
Yes I dont need the drain tube either. And I assume they send everything as a package regardless of application...so the extras are included for different cars.
What type of drains do you have on your RX cans? Mine came with an awful one I changed it to a drain cock type
Ryan
Ryan
Source please. Thank you for the time taken to reply.
I didn't use any of the barbed fittings that came with my RX catch can. I just put a cup underneath the can when I need to drain.
Amazon
Ryan
Amazon
Ryan
Is that the valve that originally came on the catch can or is that the one you put on?
I ask because that looks exactly like the ball valve that came on mine.
No I added that's why I asked what comes on them now. The old valve was awful and people complained about them. Glad they changed them out.
Ryan
    • Follows the motif on the Sierra EV.  Satin finsh to the lower bumper area, painted above:   Elevation       Denali
    • Not exactly what I was hoping for, but I do like it. I wonder if they'll bring back Smokey Quartz Metallic? 🤔 https://gmauthority.com/blog/2026/06/here-is-the-all-new-2027-gmc-sierra-1500/
