Is there a site that tracks which makes/engines are known to have deposit issues on their DI engines?
All DI engines have deposit issues. It's inherent to the design of a direct injection engine regardless of make or model. There really isn't anything to track in that regard.
Edited by Silverado-Hareek
What's surprising to me is how much performance loss - gain people related about commercially available intake treatments for relatively small deposits.
Edited by spurshot
But I have only actually seen issues reported for the German makes. Are there others?
Yes it's true that the German makes had problems that manifested rather quickly but regardless, all DI engines will eventually have problems from deposit build up on the valves. The thing with the German makes is the problems showed up before the warranty period was up which isn't good for the manufacturer. I'm sure all DI engines are now designed to make it through the warranty and then the problems will really start mounting.
Also I believe early DI engines in Cadillacs had a lot of problems like the German makes. It seems to be more related to when the design came out and not really who released it.
Toyota is the only manufacturer I know of attempting to fix the problem by designing a system that sprays fuel on the backs of the valves at various intervals to clean them.
........ I'm sure all DI engines are now designed to make it through the warranty and then the problems will really start mounting. .......
That, you can bet on.
The veracity of your statement which I bolded is what I'm trying to figure out. I have no argument against it, but I still want to see evidence.
There are fewer vehicles without DI available each year. By the time I'm ready to buy, there may be none, or at least none that otherwise interest me. I'd like this problem solved by then. How will I know?
Anyone concerned about the LACK of oil in the intake manifold, and on the valves, with a catchcan, leading to early hour valve recession? I think the consensus is oil in the intake is bad, but has anyone reached out to GM engineering to find out if a certain amount of oil in the intake is needed for proper valve function?
The evidence is out there. Reduced airflow, sticking valves.....lots of information on the internet.
If oil was necessary for the valves to function, they would have designed an oiling system for it, not adding baffles and working to reduce the amount of oil getting on the valves and being consumed in the engine through the PCV system.
If oil was necessary for the valves to function, they would have designed an oiling system for it, .......
Well, this is GM we're talking about here ... so maybe not! :noway:
Also if oil was needed in the intake the cameros zl1/z28 and vettes wouldn't have catch cans on them from the factory.....just saying. It's obviously it's not good to have oil going through the intake.
I personally think the one post that started that long thread is a placebo effect.
z28s and Corvettes have catch cans from the factory? I can believe they added baffles to the PCV path, but catch cans? That the customer has to empty?
Edited by ghgmi
1LE camaros do come with the clean side seperator
Ryan
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   2 Members, 0 Anonymous, 587 Guests (See full list)
