RX has a cleaning method described somewhere. Maybe on their website? Going by memory you spray half a can or so of carburetor cleaner in there, shake it up, drain it, and then repeat with water to wash it out.
They say you don't need to clean it though and mention they have catch cans with 60+ thousand miles on them that have never been cleaned and perform fine. The cleaning solution I described above is from customers of theirs that they passed along. Not saying you didn't have a problem, just pointing out they've made that claim and don't clean theirs.
With that being said did you drain yours cold? I always drain mine after driving for a bit so that I know everything is hot and the oil isnt congealed or solid in any way.
I do wish RX made theirs to where you can open it up and inspect it.
Edited by Silverado-Hareek
Thanks for the info, guys.
I did drain it cold. But I've tried draining it warm very recently and nothing came out either. I'll be giving mine a cleaning. I like the carb cleaner then water flush idea. Thanks for the info [emoji106]
No problem let me know how it works. Also I'd be careful not to get any on the exterior of the can so the painted finish doesn't get messed up.
This may be of interest to those of you with the RX cans:
http://www.silveradosierra.com/ecotec3-5-3l-v8/oil-catch-can-for-2014-ecotec3-engines-t360513-270.html
Go to the second posting on the page.
Wow interesting I thought they had made a new site. I was wondering why the prices were higher too. So from what I can tell:
This is the REAL RX: http://www.revxtreme.com/
And this is the knockoff: http://www.rxspeedworks.com/
My dealings have all been through "RXSpeedWorks" which looks to be the imposter website. It would explain some little differences my can has had compared to others posted here.
I will say mine has been working about as well as others as I am catching about the same amount from what others are showing. But I am still concerned long term what to do now.
If they're copying the design it should function the same in theory. Craftsmanship may be an issue but only time will tell. The biggest difference is a true RX can for these trucks is $199 and that Speedworks place is charging $350.
With that being said, I fell for the Speedworks website when I was helping a friend look for a catch can. I made the comment "oh cool they updated their website.....but damn why are their prices going up?" So I fell for it too but luckily my friend never bought anything yet.
I think part of the upcharge also was they were selling a complete kit because mine came with the clean air separator, where the real RX site sold it separately.
I don't find the craftsmanship to be lacking on mine at all but overtime will be the true test.
That's a good point I didn't realize that. If yours is performing, I wouldn't be too concerned. Just keep an eye on it and make sure it's working and doesn't develop any vaccuum leaks. You should be good. In Canada, I'd expect around 2 oz of pure oil every 1500 miles or so in the summer and 6 oz or so of a water/oil mixture every 500-700 miles in the winter. That should be a good gauge of whether it's working properly or not based on what everyone seems to be draining from their cans.
About to order my Elite Catch can.. I've read through most of the pages here but I didn't see what most people bought for the type of fittings and type of hose. Are the Brass Hose Barbs and OEM Rubber Fuel Line Hose sufficient enough?
It really gets down to appearance. Our standard Catch Cans come with brass hose barb fittings, those can be upgraded to the electroless nickel plated hose barb fittings, or we offer the Black AN type fittings for a cleaner installation and look.
It's really just a matter of preference.
05cae05a-b3fd-44ef-aca8-ab92da5cfa21_zps
Just added the Elite Engineering clean side separator to complement my catch can. The Airaid MIT uses 5/8" hoses and barbs so I bought a 5/8" heater bypass cap to block off one port on the
MIT tube. I also bought a brass barbed 3/8" to 5/8" fitting to adapt the separator's 3/8" inlet hose to the left over 5/8" Airaid hose. I ran the supplied 1/2" hose which connects each valve cover underneath my engine cover.
Shots on the house! :D
    • We understand that intermittent AC concerns are inconvenient, @tjonesdfw, especially since they often do not show themselves when we want or need them to. We would like the opportunity to learn more about your experience with your Sierra and explore the best path of assistance moving forward. To begin, please visit: https://s.gmc.com/support-request  and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • We want you to have full confidence in your Silverado, @ceeemcgeee. Safety is our utmost priority, and we understand your concern after this experience. We would like to provide an added layer of assistance between you and your dealer as we pursue the resolutions of your transmission concerns. When you have a moment, we would like to learn more about your experience so we may explore the best path of assistance moving forward. Please visit: https://s.chevy.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • Disclosure: BlueV8 is a Supporting Vendor and sells plug-in AFM/DFM disablers.   Before you spend a dime with us — or with anyone — try the AFM disabler GM already built into your truck. It's the shifter, and it's free. ⏱ The 10-second version 🚫 Skip the M5 method if: Most of your miles are highway — M5 locks out 6th gear, so you cruise at higher RPM and burn more fuel You already know you'll forget — it only works if you do it every single drive Your lifters are already ticking — nothing that switches AFM off repairs existing damage You already run a tune or disabler — this would be doing the same job twice ✅ Worth trying if: You want AFM off today, for exactly $0 You want to test-drive V8-only life before buying anything Your driving is mostly town and short trips, where 6th gear barely matters Your truck is leased or under warranty and you won't touch the ECM — this is zero hardware, zero software 💡 The whole trick, in one paragraph Owners across GM forums keep reporting the same pattern: put the transmission in manual / range-select mode, pick M5 or lower, and AFM never activates — the truck stays in V8 the whole drive. Bump it up to M6 and V4 mode comes right back. Two of the cleaner threads on it are here and here. GM has never documented this behavior, so file it under "strong owner consensus," not gospel. The good news: it takes exactly one drive to verify on your own truck. Steps below. What "free" actually costs Effort, every drive. It's a routine, not a setting. Shift to M, tap up to 5, every time you get in. There is no set-and-forget here. 6th gear. When GM shipped trucks with AFM/DFM switched off during the 2021 chip shortage, its own estimate of the penalty was about 1 MPG — and those trucks kept every gear. In M5 you're also giving up overdrive, so expect the highway hit to be bigger than that. Patience. One Tahoe owner ran the L5 routine for two months, then got tired of it and bought a plug-in disabler — he had an extended warranty, so flashing a tune was off the table. That's not a knock on the method. That's just what month two feels like.   I put together the full instructions, limitations, and links to the original owner discussions here: https://www.bluev8.com/blogs/news/how-to-disable-afm-for-free-the-m5-method
    • Disclosure: BlueV8 is a Supporting Vendor and we sell AFM/DFM disablers. We wrote this because not every GM owner actually needs one. In some cases, regular maintenance, towing use, an existing tune, or simply using M5 makes another device unnecessary.   ⏱ The 10-second version 🚫 Skip it if… You keep the oil full and change it every ~5,000 miles. Your risk is already low. You're happy shifting into M5 every drive. That disables AFM for free. Your truck tows heavy most days. AFM barely runs under load. You already run a tune or delete kit. Done is done. It's already ticking or misfiring. You need a mechanic, not a plug-in. ✅ Worth it if… You bought it used and the oil history is a mystery. Checking the dipstick is… not your hobby. (No judgment.) You're a long-term keeper with lots of easy highway miles — exactly when AFM runs most. The V4 drone and shudder drive you nuts. You're under warranty, so a tune is off the table.   The full article includes the supporting GM bulletins and owner reports: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler
    • It`s magnetic so it`s not main or rod bearings. I would pop off a valve cover or 2 and take a good look at the rocker arms. See if you can see if any needle bearings are coming apart.
