Elite Engineering can installed, black with AN fittings.
I ordered the same thing yesterday. Are those the default fuel line hoses they offer with the kit? Are they sufficient for this setup or do they need to be upgraded to something stronger?
I am curious about this but with the RX catch can. On their website it displays: Standard hose, black/silver braided 6-3/8", black/silver braided 8-1/2".
Actually am torn between the 2 brands at the moment and I don't even have my truck yet, both seem reputable. Cost wise elite seems cheaper and has a lower cost of shipping but longer shipping times than RX.
I've read through this thread 3 times and still I am undecided, I guess I'll wait to have my truck first.
Ordered my RX Performance catch can from Jegs 3 days ago and it just showed up. came with the catch can, hoses, hardware, and very surprisingly, the clean side separator, all for $319 to my door.
The separator was shown in the image but just looked like some stock RX Performance image, so, wasn't expecting to get it as well, given on the RX Performance site, that piece alone is $99 plus the main oil separator is $389. Through Jegs, i got both for $319.
hopefully i'll get time this weekend to install it and post some pics.
They are the SAE J30R6 fuel line that came with the can. They seem fine so far, but flow is high enough you can hear the airflow through the hose with the engine running.
From inside the cab or just with the hood open?
I've only noticed hearing it a few times from outside the cab.
Hood open you can definitely hear it. With the hood closed you can only hear it right next to the driver's headlight. I cannot hear it from the cab.
Has anybody noticed decreased fuel mileage after installing? I have had a few short trips but mine seems below normal even for that.
Edited by hotrodz37
Has anybody noticed decreased fuel mileage after installing? I have had a few short trips but it seems below normal even for that.
2 vehicles, No
Ryan
2 vehicles, No
Ryan
Thanks for the quick reply Ryan. I usually average about 12.5 (all stop and go driving and only 4 miles to work). I don't drive too aggressively and it was down to 10.6mpg on the dic today. I drove over to a buddy's house tonight and it went up to 12mpg but seemed like it was creeping up much slower than normal. I guess I will keep driving it and see how it does.
No. If anything you would see an increase because that moisture and oil is not going into your intake anymore affecting the combustion parameters so your engine is working more efficiently.
Edited by Silverado-Hareek
You shouldn't notice any mileage change one way or the other. Your just lengthening the PCV circuit - it's still breathing as designed, just a longer run, and less crap ending up in your intake.
When I originally installed my RX catch can, I didn't opt for the clean side separator they offer. After finding oil in my Volant CAI tube (http://www.gm-trucks.com/forums/topic/168584-oil-in-intake-tubeanyone-else-check-theirs/), I decided to install their clean side separator. Per Tracy at RX, I was told add a hose that basically connect the two valve cover breathers together. The clean side separator goes to one of my intake tube fittings and the other fitting is capped. RX instructions: https://www.rxperformanceproducts.com/wp-content/uploads/2015/03/CLEAN-SIDE-SEPARATOR-INSTALLATION-INSTRUCTIONS-FOR-ALL-GM-DIRECT-INJECTION-V8.pdf
This may be a dumb question, but what did you use to cap the other other intake fitting?
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
