On 4/10/2020 at 4:04 PM, ftwhite said:
Transmission Fluid Flush  - bulletin #18-NA-355
That is what I thought they did on the TSB, but everyone on here is saying that you can not do a flush on the 8 speed.
Did they let you know what they were going to do before hand? How is it working now?
Fixed the vibration I had. So far so good, but still waiting to see. It did great picking up mulch today though.
I love this look, big tires on stock height, seems not lifted or maybe a bit leveled ? What is your tire size ? Have a nice day ! Robin
Why can't you do a flush on the 8-speed?
Thanks. Leveled with Fox coil overs. Replaced w/ 2.25 inch blocks in the back. 275/70 r18 Nitto Ridge Grappler (33.2 x 10.8). Top of the fenders are 39.5-40 in the rear, and 38-39 in the front. Its twisted though...in the front the right side is taller, in the back the left side is taller. Only by ~1/2 in. Never bothered to fix it.
That has been my question too, but like everything else here, you have thousands of different opinions.
On 3/22/2020 at 2:01 AM, davis86t said:
Brand New vs Now. Spent a lot of time (56k miles) enjoying it stock, but those days are over...
Love the front end change there. The general "dechroming" effect is great. Did you buy new parts, paint existing or what? I have the "same" truck (color/wheels/year/etc) and have been looking into this exact same mod path.
Found the black AT grille online at a salvage yard, and the mirror caps and door handles are new OEM. I removed the pinstripes and door trim myself, and swapped in a used set of 22” honeycomb repros. The bumpers and window belt trim are wrapped. Planning on powder coating the bumpers and replacing the window trim with new black trim. Not a big fan of vinyl wrap because of the durability. Bump into it and you’ll slice right through to the chrome...
Awesome. Thanks for the info.
Definitely going to strip the emblems, and door trim off as soon as it warms up. Have to keep my eyes peeled for a new grill, and some wrap for the bumpers.
have a buddy that does powdercoating, might reach out to him and see if he can handle the bumper.
  • Like 4
Cleant up the ol girl.
  • Like 5
3 hours ago, P.T.B.O Cam said:
I picked this little WT up the other day. Here's to the long road ahead! ?
Welcome to the site.
Congratulations on your new truck!
Seeing a similar ‘19 next to my ‘16 makes me like mine even more. Lol. Still not a fan of the 2019/2020s.
  • Like 7
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
