Available Powertrains
The Colorado is gonna get a 2.5L I-4 - 193HP / 184 lb-ft, the 3.6L V6 - 302HP / 270Lb-ft and the 2.8L Duramax - 180HP / 384 lb-ft for 2016
  • 2 months later...
I bet with a tune and exhaust etc that diesel will get some impressive numbers!
This is what I am waiting for. Can't wait to see what this engine is capable of.
