Using lowering shocks throws the camber and toe way out. My camber was at -1.9 degrees on both side and the wheels toed out big time with the drop shocks.
I misunderstood. I thought you just lowered the back because you said shocks. The front are struts. You meant struts
Yes.
Just finished up installing McGaughy's 2" drop shackles. Easy enough to do. One thing I learned that may be of some use to the next person doing the shackle installation and it may have been mentioned. Loosen the two rear bolts where the bed it mounted to the frame. Then when you are jacking the diff up it will lift the bed and allow you to remove the bolt WITHOUT having to bend the rib that is above the leaf springs. My son came over and helped me button things up and that made it go real quick. At this point I am happy with things.
Rear As found measurements from ground to center of wheel well.
Drivers side 39 3/8"
Passengers 39 1/2"
Rear As left
Drivers side 38"
Passengers 37 15/16"
Front As Found, no changes made here
Drivers side 36 1/2"
Passengers 36 5/8"
It may settle some more not sure. But I just snugged the bolts in the shackles. I wanted to put a few miles on it before torquing.
I saw earlier in this thread that the torque is 85 ft.lbs. with an additional 90 degrees. Can anyone confirm this?
Edited by Eddie 70
I've gone through this whole thread, has anyone lowered the back of their truck by just removing the block. Specifically a crew cab. Everything I find is with the block removed and drop shackles. I think that will be far to much drop on my truck and would like to see if anyone has only puller the block.
First thing I did was just remove the block. Lowers it a little, but not much.
Is there a rear shackle drop that can give me around 1/2" of drop. I have a 4.5" lift with fox coils up front and rear bds leafs with no rear blocks and fox shocks. My rear end is about 1/4" higher out back. I want to be a little higher up front and would rather use a drop shackle in the rear as long as it doesn't affect rear travel.
Most shackles are in one inch increments. You could always remove one of the overload leafs to get the 1/2 inch thickness they are.
I don't want a lot of drop just a little. Being a crew cab, I don't think mine looks like it sits up as high as a regular cab does from factory. The length of the truck makes the factory rake less noticeable.
My next question is which OEM u bolts will work with the block out. I thought I read somewhere the 99-02 or something 2wd u bolts are the right length for a leaf and axle with out the block.
One u bolts work. But you sit just as high as a regular cab. Pull the block and do a shackle. But you'll want more
2017 Silverado CCSB with 2 inch shackles and moved the block from under the leaf Springs to the top for a total of 3 inches. add16e2c6b3d289b2801b0326dfccf89.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
Why put the block on top of the leaf spring, it's not doing anything there. Why not just remove it.
Yes, it's the same 1.25" of lift, but the angle the truck sits at is different from a regular cab to a crew cab. It'll look a lot more extreme on a regular cab than a crew cab.
And what do you mean one u bolts work?
Edited by Daly
I ended up putting in a set of Belltech struts in the front of my truck,
so im sitting at 2" drop in the front and a little over 3" in the back with shackles and blocks removed from the back.
It still sits a bit high for my liking in the back, but it sounds like to go any lower I would need to go to a flip kit, havent decided yet if i want to do that, don't really like the idea of cutting on such a new vehicle, do any kits require less cutting then others?
I really only want to go down another inch or so..
And any recomendations on rear shocks for a regular cab? I hear a lot of people say everything is designed for the heavier crew cabs and ride rough on the regular cabs, the front belltech rides much better then the stock rancho's, was thinking of going with the belltech street performance 2212FF.
anyway hers a pic of how it sits now
The only thing you cut off is the bump stop bracket.
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
