just lowered my truck with crown suspension 2 front, 4 rear flip kit
truck looks good but now i have vibration issues, seems like its coming from the drive line
what is recommended to solve problem?
Check your driveline angles first. This is the most probable cause. Here's a link to some info explaining what you're looking for
https://www.drivelinesnw.com/part-trouble-shooting/vibration-analysis/angle-analysis/measuring-and-correcting-angle-problems/
thanks, im just going to call the shop tomorrow and see when i could drop it back off , and see if they can figure it out, but shims should fix the problem????
IF your angles are out of spec, then yes, shims should fix it. But the shop will need to verify that is the actual problem first.
Bell tech drop spindles now in. I'm also using drop struts at the 2'' setting.
Here's some pics of the spindles since there's not much about them online
Compared to the stock spindle
And my truck:
  • Like 4
Hey guys. New here to the forums. This may have been discussed... I have looked through some pages and honestly cant get past looking at the pictures of all the awesome trucks builds! I have a 2014 Sierra 1500 4WD Crew Cab. I want to level the truck by lowering the rear. I don't haul anything heavy or tow. However, I have to remember Mom & Dad need to get in sometimes. I was told removing the stock blocks under the leaf springs would level it with the front. Is this true? Or, is the better option to buy the lowering shackles? Thanks in advance!
I believe the stock blocks are 1.25". So in theory only removing blocks should get you 1". Adding 2" lowering shackles and removing stock block or moving block from under leaf spring to on top of leaf spring will get you 3 inches which should level the truck.
This truck has total of 3" drop in the rear.392b7020c025bfb668c99bbe74b016c5.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
Thanks for the info. Is that 4wd? What option did you use to lower?
2wd. 2inch lowering shackles and moved block from under leaf springs to the top.
On ‎3‎/‎26‎/‎2018 at 10:56 AM, Joshjuniorr said:
Finally installed my shackles this weekend. Not completely level... I'm debating on dropping it more. 5b72223bd1397abcee0f0486d1d82ef0.jpg
Also trying to get mounting hardware for my rear fender liners. No way I'm giving GM they much money for that stuff emoji23.png
Also what's your driveline angles looking like when you pull the blocks on the axle? Any degree wedges needed?
I had to get shims after shackles and removing the blocks because of vibration.  I also ended up needing to get an adjustable carrier bearing from belltech I believe.  Although my truck is a crew cab with a 6.5' bed so I have a two piece driveshaft.  I think any other configuration is just a one piece driveshaft so you probably wont need a carrier bearing.  Vibration also varies from truck to truck, yours may be fine.  If its not and you insist on ordering the shims before doing the work, buy 2* and 4* shims and one of those will likely fix the vibration.
I haven't had any issues since pulling the blocks. I'll probably still get under there and measure it since I'll eventually be pulling a small camper
here are before and after pics.
also got the drive line vibration issue fixed
My build is about 75% done, but she's on the ground with new shoes, before and current pic.
20170407_12390120180405_143647
Edited by krzyd
Needing some advice on lowering my pickup. This will be my first time lowering a vehicle. From the research I've done I think I want to do 3/5. I've been looking at different kits and found the Mcgaughys #34170 Adjustable Drop Kit. Looks pretty decent, but I have no idea. I like that if I would want to go lower I could. Any input would be great. This is the link that I found for the kit.https://reklez.com/collections/2007-2017-gm-trucks-drop-kits/products/gmc-sierra-1500-2014-2016-3-5-4-6-drop-kit
2014 Silverado High Country 4wd
Any info or input for a newbie would be awesome. Thanks
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 965 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
