16 minutes ago, CajunFries said:
Hi guys! New to the forum here. Just picked up a 2018 Silverado Crew cab standard bed few weeks ago. Looking to do a 4/6 drop with DJM kit. I’ll be using it to haul my bikes to the track. I want to get a helper bags for it but can’t really find a solid answer on what brand and model I should go with. I see some people run the McGaughy’s helper bags but I don’t see one for 2014+ models. I also saw air lift got a kit out (model 59209) but I did some research on it and people are saying it doesn’t fit The truck. Even though the site said it does. So if anyone can give me a pointer on what brand and model I need I woulda really appreciated.
Also is there anyone out there running DJM 4/6 kit on their crew cab and standard bed? Does the axle hit the frame often even without any load in the back ?
Dont do djm. Secondly for the bags. I use to have the mcg bags. Bolt in no drilling
What’s wrong with DJM kit? And what brand should I be looking into?
Balljoints go to shit quick and the ride
You need a spindle and a strut
Just this year not even including my truck I've switched 7 trucks from djm to mcg stuff
Truck picked up last night and lowering parts ordered today!  2018 Chev RCSB black out edition - 5.3 2WD w/ 3.42's
Anyone else running the McG 7" flip kit? Part # 34147
I have the mcg flip on my 16
Another question, the 2514 Belltech 2" spindles. Those will work with both cast spindles & steel arms as well as the trucks that came with the aluminum spindles & arms correct?
Most of Belltech's site states anything 16.5-18 take those 2514 spindles.
Aluminum and stamped use the same. Cast uses different
You're talking about the arms. What about the spindle?
Thats what im saying. Aluminum and stamped steel use the same lowering spindle. Cast uses a differant one
To clarify, aluminum and stamped steel control arms use the same balljoints, so they can use the same spindle. Cast steel control arms use a different balljoint, so they need a different spindle.
Check DJM website. They explained it very well. I had the same questions when I was still looking for the correct parts and what not.
Mine is a 2017 Silverado RCSB, I then checked my Spindle to make sure. DJM site mentioned about two types of spindle. A Cast Aluminum and a Cast Iron. The picture at DJM site helped me in making sure what is my stock spindle. It is a Cast Aluminium(as what djm site mentioned about 2016/2017 models).
Belltech mentioned about #2514 that fits to a Cast Aluminum spindle. So I made the decision and yes it fits perfectly.(I think all Of these are because of the Ball joint fittings,maybe)
Just check if yours are Cast Aluminum(which I believe they are), you should be all good.
Perfect, that's what I figured but couldn't find the exact info. Thanks!
I have steel arms and cast iron spindle. My brother's 16" Sierra 2WD RCSB is the same.
Edited by Dinner
Then it might not fit. Check with Belltech to be sure.
I'm calling tomorrow to be sure.
From my understanding from their site and a few others is every 16.5-18 is as follows
4WD - Alum spindles & steel arms
2WD - Iron spindles & steel arms
Someone correct me if I've got that wrong...
Edited by Dinner
