The harness from the dealer or any other online retailer will not work if you are swapping out the for the console.
Is anyone wanting to buy my floor console? I did the swap on my 2015 Silverado but I am now trading my truck in. It will come with everything less the 12V Plug, cigarette outlet in the top plate and the jump seat harness. My console has the charging pad on the armrest. $550. I’m located in North Central Wisconsin
Johnny01: IF you could pm me and let me know if you take paypal, OR what method of payment it would take? And also send me more pictures of the console from different angles. EMAIL ADDRESS is [email protected]. THANKS.
Sent from my SM-G935V using Tapatalk
On 4/3/2018 at 10:18 PM, z71tx said:
Anyone in the West Texas area need a black console? I ordered a what I thought was cocoa and I received a black instead. Still waiting to hear back from gmpartsnow. The Vin I gave them was for a cocoa interior...
Do you still have this?  Please check PM. :)  MR
On 4/1/2018 at 10:56 AM, bpaz7 said:
Hey guys I’ve been reading this thread and saw gmparts online had some stuff on back order I found this site and just ordered my stuff threw them The parts seems to be a little cheaper I didn’t try any cupons cause I didn’t want to wait! Anyway here is the breakdown hope it helps
Was this a complete console?  Came with the back piece, console lid etc?
Im not sure whats up with my post above lol. Anyway can some one do a test for me. I did the swap and android auto/carplay works from all usb ports. However reading media (such as music) only works off the glove box usb and the front usb. It does not work off the internal usb. Can some one else try it and see if it works for them.
Kinda opposite of what everyone else is doing but, who has gone from a full console to a jump seat?  Not sure I would do it but, I did like the jump seat setup in my 2014....
I'm wanting to change my black jump seat out for a center fool console. I'll send you a picture of it. It's in my 2016 chevy Silverado crew cab LT Z71 1500 and it's leather. Could you send me a picture of yours.johnny01:a885f7f33ad3f4671729455ae2989bdb.jpg
Thx for the interest but, I would need cloth as I have an LT w/ cloth seats and I am still not sure I'd wanna do the swap... More so just wondering if anyone has done it...
I have a cloth jumpseat with full wiring harness in tact that is nearly flawless if you are interested in purchasing.
22 hours ago, jacobrmiller05 said:
a few people have done it, but there will be a hole in the carpet that is visible.
Ah good point - I guess the cost of a new carpet OR an over the hump floor liner would have to be factored into the project...
Thanks for the offer, if I decide to go that route I will hit you up. Right now it sounds like too much work to make the swap given the other things I have occupying my time at the moment...
Just installed my swap yesterday, looks great and everything works well thanks to the great @pgamboa
Have 2 questions though for people who have fully completed this swap.
1. For the life of me I cannot figure out how to get the side trim pieces on with the console itself bolted in. Do these side trim pieces need to be installed with the center console unbolted?
2. Does anyone else's cup holders rattle with a drink in them when going over a bump? Trying to figure out what could be loose and how to fix it.
You just have to play with it a little I had my seats out
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
