5 hours ago, pgamboa said:
Removed the magnet?
Yep and removed the plastic piece over top of it as well. I make my phone face the opposite way and charges really well now
What magnet. I have the 18 module. But my phone case wont allow the phone to sit flat
I don’t have the 18 module. I have the 16-17 module. Inside it there is a magnet, and a plastic sleeve that prevent the charger from working properly. I removed those and it works flawlessly
Maybe I should pop open the 18 module and see if it has that
Pretty sure the 18 module doesn’t. It has 3 charging rings compared to my 1 charging ring.
Hi
I recently bought a 2017 Silverado 1500 LT Z71, I have the jump seat, but I hate it. I want to do a swap to the full floor console. I have been reading the forum and been seeing alot of things that are not working. I dont want to lose features. I have been taking down the part numbers and what not.
However I cannot figure out the part numbers for black leather with black stitching.
Also I would appreciate any tips or things I should be aware of.
If anyone has any leads on a complete console shoot me a message.
5 hours ago, rae185 said:
Hi
Check out the first post, everything is plug and play and EVERYTHING works. No lost features
There's several part numbers listed in this thread as well
Johnny01: Contact Corbin at gmppartsnow.com and have him to send you a list and diagrams of all the parts. Pgamboa can fix you up with the PNP harness and he has a video on YouTube that shows you how to install all the wiring where everything works.
Sent from my SM-G935V using Tapatalk
I saw that video. I'm just curious as to what part numbers go to what colors and color stitching, and I will shoot gmpartsnow.com a email requesting Corbin to get ahold of me thank you.
Ok thanks so much!
On 5/6/2018 at 8:34 AM, frankinbus said:
Nope , Just did a swap in a W/T single cab , Looks awesome , with floor shifter for 4 wheel
Do you have a picture of it? I have the floor shift also.
Thanks
Edited by DONWT15
Your best bet and what they will ask you for is a vin number.  What I did was searched cars.com and any other vehicle sites for the truck that has exactly the console you want and then give them the vin from that.  That is the best way to match it up.  Those guys are very thorough in making sure its complete.  I can send you my quote but, its somewhere in this thread as well.
I just got a quote of $912. I thought the console came with the armrest it’s showing in the quote I have to purchase it separate?
mitchell95: I just finished my swap. Ordered all partsfrom Corbin with gmpartsnow.com. I spent hours researching prices and they were by far the cheapest to the door. I have a 2018 Silverado Crew with black interior w/silver stiching.
84288040-Console $390.79
84092079-Upper Trim Panel $146.57
22467516-Side Trim $52.96
23467516-Side Trim $25.30
22776807-Front Bracket $16.58
84022323-Cable $16.46
19119050-Cable $24.13
11609982-Bolt x 2 $3.26ea
Total $680.31
10% Discount -$67.93
Shipping to my location $54.53
Grand Total $665.91
You will also need the wire harness from pgamboa he will hook you up...
Hope this helps
I will admit my mistake, I hadn't quoted one in a few weeks so it was my mistake adding the lid when it was not needed. That is why his quote was higher.....my bad!
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 684 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
