5 hours ago, pgamboa said:
Removed the magnet?
Yep and removed the plastic piece over top of it as well. I make my phone face the opposite way and charges really well now
What magnet. I have the 18 module. But my phone case wont allow the phone to sit flat
I don’t have the 18 module. I have the 16-17 module. Inside it there is a magnet, and a plastic sleeve that prevent the charger from working properly. I removed those and it works flawlessly
Maybe I should pop open the 18 module and see if it has that
Pretty sure the 18 module doesn’t. It has 3 charging rings compared to my 1 charging ring.
Hi
I recently bought a 2017 Silverado 1500 LT Z71, I have the jump seat, but I hate it. I want to do a swap to the full floor console. I have been reading the forum and been seeing alot of things that are not working. I dont want to lose features. I have been taking down the part numbers and what not.
However I cannot figure out the part numbers for black leather with black stitching.
Also I would appreciate any tips or things I should be aware of.
If anyone has any leads on a complete console shoot me a message.
5 hours ago, rae185 said:
Hi
Check out the first post, everything is plug and play and EVERYTHING works. No lost features
There's several part numbers listed in this thread as well
Johnny01: Contact Corbin at gmppartsnow.com and have him to send you a list and diagrams of all the parts. Pgamboa can fix you up with the PNP harness and he has a video on YouTube that shows you how to install all the wiring where everything works.
Sent from my SM-G935V using Tapatalk
I saw that video. I'm just curious as to what part numbers go to what colors and color stitching, and I will shoot gmpartsnow.com a email requesting Corbin to get ahold of me thank you.
Ok thanks so much!
On 5/6/2018 at 8:34 AM, frankinbus said:
Nope , Just did a swap in a W/T single cab , Looks awesome , with floor shifter for 4 wheel
Do you have a picture of it? I have the floor shift also.
Thanks
Edited by DONWT15
Your best bet and what they will ask you for is a vin number.  What I did was searched cars.com and any other vehicle sites for the truck that has exactly the console you want and then give them the vin from that.  That is the best way to match it up.  Those guys are very thorough in making sure its complete.  I can send you my quote but, its somewhere in this thread as well.
I just got a quote of $912. I thought the console came with the armrest it’s showing in the quote I have to purchase it separate?
mitchell95: I just finished my swap. Ordered all partsfrom Corbin with gmpartsnow.com. I spent hours researching prices and they were by far the cheapest to the door. I have a 2018 Silverado Crew with black interior w/silver stiching.
84288040-Console $390.79
84092079-Upper Trim Panel $146.57
22467516-Side Trim $52.96
23467516-Side Trim $25.30
22776807-Front Bracket $16.58
84022323-Cable $16.46
19119050-Cable $24.13
11609982-Bolt x 2 $3.26ea
Total $680.31
10% Discount -$67.93
Shipping to my location $54.53
Grand Total $665.91
You will also need the wire harness from pgamboa he will hook you up...
Hope this helps
I will admit my mistake, I hadn't quoted one in a few weeks so it was my mistake adding the lid when it was not needed. That is why his quote was higher.....my bad!
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
