Don't have to take off the plastic corner step if you just have a sticky back LED light and just drill a hole through the corner and run the wires out like Mike did
Added LED's to the bumper step.
Looks good.
I've had the LED's sitting here for a couple of months, your post is motivating me to get out and install mine.
Have you tested the windnoise yet? how about glare off the hood?
Not really any glare when aimed right. And I'll find out about noise today when I'm off
Sent from my SM-N920V using Tapatalk
So you had to loosen the bed bolts didn't you? I tried doing the same thing as you before but got lazy and haven't messed with it since lol
I don't think you have to take the bumper off. Anzo sells replacement steps that have LED's in the face of them and if you follow their installation instructions they show you how to remove the corner steps:
http://www.anzousa.com/media/installation/e0da1a5a.pdf
Nope. Took I think 8 bolts out and it slid out. It may be possible without removing it. I had to vinyl wrap it so It was coming off anyways. Right behind the steps are a pair of wire looms. The one with the red & black wire are the ones you tap into.
Edited by zmnypit
Not today but this weekend I installed a set of Fox 2.0 coilovers! So far they have been great, the ride is 100x better than stock coilovers with the RC 2" kit. The Fox 2.0's gave me just over 2" of total lift also.
Cost?
Finished up with my Elite catch can install and a Black Bear tune. All I can say is WOW!
Edited by krdeal
There was a lot of noise to begin with but I was able to cut it down some with some mods.
I had the i1000 tuner but it kept giving me issues, wondering if the i2 would give me less issues? Let us know how you like it!
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
    • Looking for a clean way to add serious lighting to your 2019+ GMC Sierra 1500? Our M&R Automotive 40" SLIM Light Bar Kit was engineered to deliver maximum performance while maintaining a factory-inspired appearance.   Features: • Designed specifically for 2019+ GMC Sierra 1500 models • High-output 40" SLIM LED light bar • Clean, integrated grille-mounted design • No cutting or drilling required • Bolt-on installation using vehicle-specific brackets • OEM-style fit and finish   Whether you're hitting the trails, exploring backroads, or need additional visibility off-road, this kit provides powerful illumination without compromising the look of your truck.   For product videos, light output demonstrations, and installation content, check out our YouTube channel:   https://www.youtube.com/channel/UC3lutWP54fkXBl3iFLDJR-A Have questions about fitment or installation? We'd be happy to help.
    • $3.63 today. Inching down. Plenty still over $4.20
