12 hours ago, Reddirt10 said:
Got some new shoes today! Pretty stoked about that!162a3401c93f95eb33ee3ab42aacac12.jpg
Sharp looking truck.  The color scheme c/w tint will makes it stand out.  I regularly receive compliments on my stock brown truck.  You must get inundated with lookie-loos!
Thanks man! Yeah it's a popular truck in my neighborhood lol!
20 hours ago, boombalatty said:
Found some vinyl pretty close to Summit White and tried wrapping one of the three chrome bars of my LT grille. It ... happened, I guess.  First time ever working with vinyl so major learning curve.
But on the upside, after I butchered the white I put some black matte on the bowtie.  I cut the bowtie along the wrong ridge and ended up with an 1/8" gold border around the matte and I like it. Reminds me of the ol Heartbeat logo.
What brand white vinyl did you use? Looking into wrapping the front grill and headlights white also
Vvivid Black Matte 60" x 1ft Car Wrap Vinyl Roll with Air Release 3MIL-VViViD8.  https://www.amazon.com/gp/product/B00L9JAS80/  There's enough that you can be terrible at wrapping and still have leftovers after wrapping all three emblems.
I let my hack job stay on for the day so I could look at it and nitpick the color difference between it and the Summit White, but it's pretty darn close.  Close enough that I wouldn't mind leaving it on there if it didn't look like a mess.  That one was the VViViD White High Gloss Realistic Paint-Like Microfinish Vinyl Wrap: https://www.amazon.com/gp/product/B00YLFQ7W0/
Edited to add glorious day time pictures.
hackjob.jpg.2b2aacf196d6ec64dac12e8f7395e973.jpghackjob3.jpg.c3b980be1584ab0ccff2f024b7b09174.jpg
Edited by boombalatty
I've been thinking about turning the white letters out so I made this quick edit. What do you guys think?
Do It!.  I think it gives a sport/classy look to the truck. White letters out on mine:
Some previous lengthy discussions on this topic can be found on this forum. I  prefer no white lettering, not even "turned-in".  The bold white advertising takes away from the look, imo.   White walls or red stripes on sedans I could understand as a custom/retro look.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Is it an overlay or replacement? How did you attach the GMC?
On 1/29/2018 at 10:02 PM, Lgetz said:
Pic of my headlight.  Housing got clouded and with lots of condensation pretty quick.
that's not good~
It's considered an insert but it's basically a replacement as you have to cut out the center of the old grille and reuse the shell. It is also available as an entire assembly but I chose to remove the center portion as opposed to color matching a new shell. The emblem is attached with self tapping screws to the protruding plastic nubs that stick out. (The original grille has push tabs that go into these nubs that are not utilized by the new grille.)
Looks good. I like this style on the Sierra's much better than the Silverado's. I hate my honeycomb grill but can't find a aftermarket grill I like for my '15 Silverado.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
