Took the rear blocks out and bought an air wrench halfway through the job.  Sure you can do it by hand, but you really don't want to.
How much did it lower the back and do you have magneride? Was just curious...any pics of results and job to remove the block.
Sent from my SM-N950U using Tapatalk
Nope, just the regular GM suspension.  Before the air tools I made some mistakes on jack placement and one side ended up costing me about two hours with hand tools and apologizing to a neighbor when my wheel went on an adventure.
After the air wrench and knowing where to put the jack stands and floor jack, the passenger side took less than twenty minutes.  Embarrassingly faster.  I do have drop shackles on too so it dropped it about dead even.
As for pictures, you might want to take a swim through the leveling kits thread that's stickied.  Lots of pics and info in there.    This post has pics with the drop shackles on and blocks removed.
Edited by boombalatty
Forgot the link. DUR
Transmission drop and fill at the dealer this week. Today I did the transfer case fluid. Front and rear diff’s next weekend. Amazed at the shavings 8346fde14674a43f088ef6c5c575c7c6.jpg
Wow that's a lot of shavings!  Is that normal?
I’ve heard it’s perfectly normal for first fluid change but should be less the next go round. I just hit 60k so this is a first for all drivetrain
Mine looked like that at 10k, has barely had a fuzz on it since...
Steve
2012 2500hd 6.0l
Steve
2012 2500hd 6.0l
i changed mine around 35k mine looked similar also did the rear diff at the same time. it was pretty gross aswell cleaned it up really good before i replaced seal (which was a pain to find) preventative maintenance for the win!
Did you put anything around the housing before placing the seal back on?
Do you need to replace the transfer case bolt when you change the fluid? I read online that it needs to be replaced or it could snap off.
The drain plug? No need to replace, just don't overtighten...
Steve
2012 2500hd 6.0l
Steve
2012 2500hd 6.0l
Ok thanks, maybe I'll do that this week then.
Make sure you loosen the fill plug first, then the drain...sometimes they seize and are difficult to remove.
Steve
2012 2500hd 6.0l
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
