12 hours ago, Reddirt10 said:
Got some new shoes today! Pretty stoked about that!162a3401c93f95eb33ee3ab42aacac12.jpg
Sent from my SM-N950U using Tapatalk
Sharp looking truck.  The color scheme c/w tint will makes it stand out.  I regularly receive compliments on my stock brown truck.  You must get inundated with lookie-loos!
Thanks man! Yeah it's a popular truck in my neighborhood lol!
20 hours ago, boombalatty said:
Found some vinyl pretty close to Summit White and tried wrapping one of the three chrome bars of my LT grille. It ... happened, I guess.  First time ever working with vinyl so major learning curve.
But on the upside, after I butchered the white I put some black matte on the bowtie.  I cut the bowtie along the wrong ridge and ended up with an 1/8" gold border around the matte and I like it. Reminds me of the ol Heartbeat logo.
What brand white vinyl did you use? Looking into wrapping the front grill and headlights white also
Vvivid Black Matte 60" x 1ft Car Wrap Vinyl Roll with Air Release 3MIL-VViViD8.  https://www.amazon.com/gp/product/B00L9JAS80/  There's enough that you can be terrible at wrapping and still have leftovers after wrapping all three emblems.
I let my hack job stay on for the day so I could look at it and nitpick the color difference between it and the Summit White, but it's pretty darn close.  Close enough that I wouldn't mind leaving it on there if it didn't look like a mess.  That one was the VViViD White High Gloss Realistic Paint-Like Microfinish Vinyl Wrap: https://www.amazon.com/gp/product/B00YLFQ7W0/
Edited to add glorious day time pictures.
hackjob.jpg.2b2aacf196d6ec64dac12e8f7395e973.jpghackjob3.jpg.c3b980be1584ab0ccff2f024b7b09174.jpg
Edited by boombalatty
I've been thinking about turning the white letters out so I made this quick edit. What do you guys think?
  • Like 3
Do It!.  I think it gives a sport/classy look to the truck. White letters out on mine:
Some previous lengthy discussions on this topic can be found on this forum. I  prefer no white lettering, not even "turned-in".  The bold white advertising takes away from the look, imo.   White walls or red stripes on sedans I could understand as a custom/retro look.
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • Like 3
Is it an overlay or replacement? How did you attach the GMC?
On 1/29/2018 at 10:02 PM, Lgetz said:
Pic of my headlight.  Housing got clouded and with lots of condensation pretty quick.
that's not good~
It's considered an insert but it's basically a replacement as you have to cut out the center of the old grille and reuse the shell. It is also available as an entire assembly but I chose to remove the center portion as opposed to color matching a new shell. The emblem is attached with self tapping screws to the protruding plastic nubs that stick out. (The original grille has push tabs that go into these nubs that are not utilized by the new grille.)
Looks good. I like this style on the Sierra's much better than the Silverado's. I hate my honeycomb grill but can't find a aftermarket grill I like for my '15 Silverado.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
