Installed a gloss black vinyl emblem overlay, not too sure how I feel about it. I messed up on a couple spots and you can see the red. I may end up peeling them off and spray painting them.
22 hours ago, ChristopherDB said:
Been wanting to install footwell lights ever since I bought the truck last week. Couldn't wait any longer for the LED strips to arrive so I ran to the auto parts store and bought some just before they closed. Forgot the wire so I had to run to Home Depot as they are open late. Got home, forgot the t-tap to tap into the dome me lighting, so back to Home Depot just before they close at 10PM. My projects always require at least three trips to the hardware store. 3 hours later and I finally finished the fronts!
That is slick... Where did you tap into the dome lights? Would love to do this myself this weekend!
I tapped into the wire demonstrated in this video:
I then shined a light from the driver side through the font of the console and from the passenger side I could see the light shining through and used a fish tape to pull the wire through to power the LED strip for the passenger feet.
These were the LED strips I picked up locally, which matched perfectly with the factory LED dome lighting. https://shop.advanceautoparts.com/p/alpena-ezlink-flexled-24-starter-flexible-led-light-strip-kit-white-77066/11579331-P?searchTerm=77066
Edited by ChristopherDB
Plasti dipped the 3 chrome strips in my grill and the chrome bottom behind the license plate.8c646c05f7d7738f44d97b60a85da550.jpgf5ba9555ce13afe16b21281591838725.jpg
Sent from my SM-G950U using Tapatalk
  • Like 4
They look like the GMC All Terrain wheels, painted/powder coated black.
Yeah they're black GMC replicas.
Dropped my truck off at the dealer again for coolant fogging up interior. Last week they replaced the radiator and thermostat for too many thermocycles but the issue was still there. I got the call today it will be $1,100 for the heater core. GM offered about $100 towards the repair. I'm disappointed to say the least.
On 2018-04-06 at 4:53 PM, Coxryan1 said:
RC level installed, midnight edition wheels and Cooper rubber!ff18ff123f3081b977d7290004eece83.jpgb41fe29d10c0af9eea28b88064d6b2a8.jpg1f3f76a7e89d4171a9f1972604a01e13.jpga930e6b0efed22d389db6d5892f4bb85.jpg
What brand running boards do you have on?
Did mine in green. Matches the rain forest green truck
Can you show a pic of where you mounted the led light strips under the dash on both sides?
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
