16 hours ago, JesseSPI said:
Just installed the new amp xtreme steps. I’m happy with them.
Tempted to go the Amp route but also do like the look of physically deployed steps. Still going back and forth... hear horror stories in the Rust Belt about these seizing up and/or freezing the motor on cold, wet, icy days.
On 2/18/2020 at 1:33 PM, Frankielozano214 said:
Any pictures?
I hear you. I took a while to decide. I originally was thinking about the RBP power steps because of the dual motors in them and then these new amp Xtreme steps came out. Supposedly these are the answer to the previous failures in that they have dual motors to power through being frozen but time will tell I’ll keep you posted.
when I bought this truck it had already been lowered, I fixed some stuff that I found when I first bought it that the careless previous owner or installer overlooked, I thought I was all set, today I hit a speed bump kind of hard and bam abs/service traction/service trailer brake came on, thought I had maybe broke the trailer brake controller, got under it and and found that whoever did the drop ran the passenger side abs harness between the axle and the frame so if it bottoms out it pinches the wire. confirmed with a scan, I was surprised to find out the  sensor is pretty cheap like $20 so I don't have to fix the harness I will just grab a new one and route it correctly.
On 2/19/2020 at 9:51 PM, JesseSPI said:
Are the step lights blue? I thought they came with white LED.
They are supposed to be white but they look blue to me as well. They are also pretty dim.
I am getting close to pulling the trigger now that they have the Xtreme, might have to run some different lights though.
How was install? Pretty easy?
It wasn’t bad. Just time consuming. If you want to change up the lights it would be really easy the way the set up is. You would have no problem.
Once the project was done I went to test it out and the opposite side would deploy. This was frustrating but I switched the signal wires around and everything worked out fine after. The wires I am referring to are the ones that go to your obd2 port. They are a purple wire and a purple with black stripe. I matched them how the instructions said but I guess that was a mistake on their harness. Not a big deal to switch.
If you get them and have any questions on the install I can help. It’s all fresh in my mind since I just them.
Edited by JesseSPI
These running boards are one of the best options I have added to my truck. Makes the truck look clean. They tuck right underneath. The light on mine is white. They are LEDs, just not super-bright. Highly recommend getting the plug-n-play wiring kit and not hard wiring inside the door, the wiring kit alone probably saves an hour on each side. Overall install was less than 2 hours.
On 2/21/2020 at 8:16 AM, Aboogie808 said:
Took her in the woods to look for land to purchase. I had a great time.
Your truck looks good! Did you buy black headlight trim, grill, and bumber or did you plasti dip it?
Aloha and blessings. No, I rhino lined everything. Came out really good. I use to have plasti dipped it before, but wanted it to last longer.
I did the diode mod to keep my fogs on with my high beams today.  I can/t wait for tomorrow to finally rinse off my truck.  It's supposed to be 50* here.  Not washing, just a foam canon and a thorough rinse.  lol.
It was nice out today so I gave the truck some lovin.
Those are nice pods. Where did you get them from?
Sent from my SM-N975U1 using Tapatalk
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
