5 minutes ago, Crazyjoker77 said:
well quickly wrapped the B-pillars on the one side to see how it looks.  Whats everyone's opinion.
I like the roll bar looks
Bad ass do you have a side pic
I installed a new starter 2008 gmc Sierra ... 170.000miles on the factory one.. I think that was a pretty good starter lol
Sent from my SM-G892A using Tapatalk
We did a swap, he sent me his chrome at the same time I sent him my black. Nice dealing with a good guy. Thanks again Mike!
Wrapped the other side gonna rock it for a couple weeks see if the carbon pillars grow on me.  Also gave it long overdue wash.
7 hours ago, Kurtj29 said:
How did you do it - plastidip, vinyl?
Swapped my chrome trim for another members black trim (Bobaloo22)
16 hours ago, Crankycolnago said:
Finally finished the bed lights and plasti dipped the chrome tailgate letters
Details on this? What strip is that and what kind of wiring did you use?
I used this one Megulla Truck Bed Light Strips, LED Truck Bed Lighting Kit with On/Off Switch and Fuse -Super Bright LED, IP67 Waterproof -for Trucks, Trailers, Pickups, RVs, Vans and Cargos (Cool White, 6000K) https://www.amazon.com/dp/B0711FYXSM/ref=cm_sw_r_cp_api_i_I2srCbPSWVYD4. I tapped in to the trailer light connector quite easy to do actually .
Installed rgb halos on my fog lights, think its pretty cool i can choose to sync with my rock lights and with my demon eyes or just work them by themselves3ed5dbf6a84bf65a8a486fbca7c06ac6.jpg
10 hours ago, lapoolboy said:
Those tires...gah!
Cris will be along shortly to browbeat you into submission.............
Shakey
  • Like 3
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
