Love the carbon fiber look on the inside. I wish this was easy enough I could do it. Sometimes the sun hits those just right and they’ll blind you! I hate that.
Thanks! It does take some patience. The Chevy front/back emblem took over an hour each. Doing one letter at a time with a heat gun, and a new sharp blade with each letter was the key. Glad when it was done. Haha..
I got the vivid dry carbon, so it's not shiney and not smooth, has a little texture feel to it. Plus with tinted windows, shouldn't be a problem. Thought my center console will hit the sun and shine too.. so far so good. Shine in the picture"s from the flash on the camera..
Sent from my SM-N986U1 using Tapatalk
Finished up wrapping the trim on the steering wheel, talk about a pain to put back in without taking the airbag out first..
Also, finally finished the vynle wrap on the other front emblem and installed, looks so much better..
Do you clean your steering wheel? Looks close to brand new from the picture. If so what do you use?
I just don't death grip the wheel. And I don't really try to touch it with dirty hands.. [emoji28] other than that, just normal wipe downs, nothing special.
That looks really great. Kinda want to do something similar with the heritage bowtie with black gloss wrap on my midnight edition. I'm only holding back because I Have the illuminated bowtie in front. Overall excellent looking
Sent from my SM-G986U1 using Tapatalk
  • Like 3
Thanks!
Yeah, I was going back between getting the illuminated bowtie as well.. was trying to figure how I could put the heritage part in there.. haha
decided to just stick with the heritage bowtie.
Thanks!
Haha thats funny you say that cause I actually wanted an illuminated heritage bowtie! I also was thinking of wrapping it in bronze because I want to do a black and bronze motif with my build
2 hours ago, stassin22 said:
Added dl3 mirrors and some switchback mirror caps
where did you get the mirror caps?
Caps themselves came from eBay had them painted and then retrofitted the switchbacks myself but I have seen some companies sell them
What’s the deal with these blinker-ized door handles??? Is that a retro fit as well??
  • Like 4
got a link? my ebay fu isn't working
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
