38 minutes ago, dieselfan1 said:
I took a picture of it. Haven't taken many pictures since I did the body lift and 38's.
For a big girl I think she purty.emoji7.pngemoji3059.png0695285d007ec284a80372a815edf2fa.jpg
Sent from my SM-G991U using Tapatalk
That is looking sharp and done right!
Nice!
Big Sexy! 👍
Painted my traction bars today. I’ll get them back on tomorrow.
Did a few things today. First I replaced the factory horns with new ones, easier than I thought, didn't even have to pull off the front grille. Second, installed the Pedal Commander. And last, probably the easiest mod anyone can do, swapped out the remote. Got two for around $21 on Amazon. b8d4da3896e079e126dd2f486f1d1174.jpg812a3567a94f6311e69619447a82d85d.jpg0317b9931693cd973d6d0dda854a304c.jpg
Sent from my SM-G973U using Tapatalk
  • Like 3
Big sexy bish!!!🤣 diggin the 38s tho 💯💯💯
got a link to those fob covers?
I re sprayed my a-pillars black again using Dupli-Color adhesion promoter and Vinyl/Fabric flexible coating. I originally sprayed them with SEM Bumper Coater at the recommendation of the paint shop owner but that did not hold up well at all so we’ll see how this does.
  • Like 3
Started cleaning up the Borla exhaust.
Cleans up pretty good with some 800 grit sandpaper. My goal is to have it clean as a whistle underneath the whole truck by next week.
I'm changing the two rubber hangers on the tailpipes to shorter ones too. The body lift made the exhaust lower than the bumper.
I got a good start on it this weekend.
Then in a couple weeks the paint correction. Should be ready in a few weeks for the local Shows at Dennys and Culvers.[emoji1][emoji1787][emoji2957][emoji13]9bb37308ff0b54725d1102b4872d721f.jpg
  • Like 4
look's good - is that a flat black ??  If i did my rear , it has seat belts going through them .
Thanks and it is flat black although it does have a little sheen to it very close to that of the dash.
Thanks, after reviewing several I see these wear out quickly I opted to go with the ajt designs fob case
https://www.ajtdesign-llc.com/online-store/Chevy-GMC-Truck-c42624008
I like it so far. I've noticed the buttons are a little harder, more firmer, but I like it and I prefer the looks of this one over others I've seen. And I've got two so if one messes up, I'm good.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
