i like the red.. goes with that theme you got going on!..
Thank you, I just find its a little to bright may grow on me when it fades a little.
I wanted to just do it gloss black and the tow hooks red little upset I couldn’t get the one tow hook off but I’ll try again when my neck isn’t sore from laying under the truck lol
U mean -15? I’m going with the -24 offset. Probably going to shave the wheel well a little.
I really like how the Silverados look in the prerunner style! Looking forward on how yours turns out!
No sir, +15. -15 would be an insane amount of tire and rim sticking out
Pulled a Pgamboa
Be careful... pulling a pgamboa means you’re truck will never be 100% intact. LOL!! [emoji23]
  • Like 4
  • Haha 3
I was afraid you’d say that lol
Gotta love this....truck parked no where near any cars and someone hits my bumper and top piece. I just had the front end repainted 3 months ago....6aeabda3fee39adee452c4f727f2853c.jpg
  • Sad 2
8 minutes ago, Waterfowler41 said:
Took the valence off last night for a little change of pace.
What ever happened to the grille guard man? Love that spoiler on her though, adds a nice little something extra.
I have a severe case of parts ADD and needed to fit my truck in my new garage. That bad boy added 12" to the front of my truck.
The spoiler got some mixed reviews on the GM/Chevy FB groups but I like it a lot.  The quality is awesome.
Ah, yeah fair enough. The added length is a bit of a pain on these already long wide turning trucks. I'm looking at adding a grille guard similar to what you've got here, was wanting one with a winch option like an oldschool warn grille guard but have been struggling to find exactly what I want. Truck looks great though.
When you going to wrap the interior to match the seats?
I know I want to do something with old man woodgrain but not sure what.  Back and forth between adding Max 5 to them or going with a brushed aluminum look like my stereo surround.  I love camo as much as the next guy but sometimes its too much and I haven't been able to find a quality wrap material in Max 5. I'd like a nice gloss finish....
Running boards, brakes, and shocks are next...
Ah, yeah I think most wraps are matte. Def a balance but yours is well done with properly fitted seat covers not the autozone specials so I think if you choose to wrap it can be a nice simple touch. To each their own though. I'm a big fan of kryptek and am wrapping mine as soon as the wrap shows up.
That sucks! Hope you had a dash cam that picked it up.
Unfortunately no I don’t have one...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
