LED Accent / Puddle Light Pods & Strips
MotoMedic
At $20 a pod, it was cheaper to go ahead and buy the Vision X eight light kit. Now just gotta figure out where I want to put them! ha. They're pretty bright, so maybe 2 to 4 as side puddle lights. Not sure about the rest yet....
  • Replies 73
Maybe a brighter light for under the hood if you have extras? Or extra rail lights in the bed.
Never thought of the under hood light... awesome idea.
Very good idea.
Tapatalk via Moto X
I'm interested in seeing what you do with these, I was looking at buying it the other day but couldn't figure out exactly what I wanted to do with them.
Are these surface mount? I was thinking of mounting one on the middle side of the fog lamp plastic bucket. It could possibly light up the side of the viewing area, so when you are turning at night, you would have illumination, similar to the a cornering light. Might end the issue of turning into the dark and landing into a culvert ditch.
Have you got a part number for these? I'm having a heckuva time finding what you have. Also, the pods I did find are colored instead of white.
They can surface mount (completely flat on back) or be mounting from behind surface (drill 1 1/2" hole & push through opening). Bases are aluminum.
Not sure if they're bright enough to function as cornering lights, but if they are, you could put them in the corners of the air dam for a cleaner install/look.
*I'm going to do a factory puddle light v/s pod light comparison this weekend... I'll post pics when I do.
Individual pods: http://www.visionxusa.com/Accent_Lighting-Pods/c125_18/index.html
8-pod kit with flasher: http://www.visionxusa.com/Accent_Lighting-Tantrum/c125_24/index.html
They have several colors, including white. The kit basically gives you the flasher & eight pods for the price of six. If you want five pods or less, buy them individual.
Did some basic testing tonight....
The first two attached pics are one stock puddle light v/s one LED pod light. You can tell in the pics the pod is more focused, but the camera doesn't do them justice. The pod puts significantly more light on the ground, and so the iPhone cam compensates for the increase in reflected light. One per side will be sufficient for extra entry/exit lighting, but I might just do two per side because I have eight of them! ha
For the third pic, I closed the bed cover, held one pod in the upper rear corner, and closed the tailgate about 90% (leaving just enough open to dip my iPhone in to take the pic). You can see they put out about as much as an average $10-15 LED flashlight. While that doesn't sound impressive, remember they are only meant to be accent lights.
I believe they could work as cornering lights, though probably only in the country versus a semi-lit city setting.
I am working on something similar but with strips from AAC in Louisiana made by Oracle. There are a couple 2014s on my to do list for these
..in Metairie?
....They have several colors, including white.
OK, thanks! I ordered two whites. Going to play with the idea of cornering lights. Will merely trigger them for now via the fog lights.
  • 4 weeks later...
I am looking at ordering some light pods for the side of my truck. Coming from my old 02 Yukon which gave off more light than most headlights do, I feel like I'm sitting in the dark sometimes with this new truck. I am looking at putting some lights on the side as puddle lights / rock crawling lights (or thats what they are called in the kit) and the way I would like to do it, is since underbody lights are illegal here in Louisiana on everything but a motorcycle, does anyone know how to make it so that the lights would come on ONLY when the truck is either A) when the dome lights come on BUT ONLY if the truck is in park, or B) when I unlock the car since that only happens when the truck is in park.
My biggest thing is I just don't want to end up turning them on while I'm driving since the cops in my area are notorious for pulling people over for the smallest of things, especially if they drive a brand new vehicle.
If it helps, the lights I'm planning on getting can be found here:
I'll be ordering the WHITE ones btw!
http://www.xkglow.com/ProductDetails.asp?ProductCode=XK084001%2D8&CartID=1
I'm thinking about ordering 2 sets. maybe 3-4 pods per side, a 2-3 under hood on their own switch mounted under the hood with the lights, and 2 for extra bed lights, and the rest as foot well lighting in the cab hooked up with the interior dome lights for each seating position (which will be a pain to wire)
Thanks in advance for any help!
Does anyone know how to make it so that the lights would come on ONLY when the truck is either A) when the dome lights come on BUT ONLY if the truck is in park, or B) when I unlock the car since that only happens when the truck is in park.
You should be able to wire a relay off the puddle light in side mirror, so the LED pods/lights only come on when you unlock/lock at night.
That's my plan... whenever I eventually get around to it. My pods are still sitting on my shelf.
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
