You're not really going to lose any HP, it'll be the same amount going to the rear. The 285/55's will be taller then the 275/55's and take a little more rpm to turn them. You might lose 1-3mpg depending on the truck…
I need some help. I have a '14 SLT 5.3 with 3.42 gears and 2.5 level. My question is, I have stock 275/55/20 tires that weigh 39 lbs. I want to put on 285/55/20 Terra grapplers that weigh 58 lbs. That is 19 lbs more per corner but I'm leaving the diameter the same. How much rear wheel HP will I lose to the ground and how much will the weight effect MPG as well.
I have the same engine/gears but with a 6.5" lift, I went with 35" tires on 18" wheels and I couldn't really notice the power loss driving around town. It's on the highway when you'll go to pass someone that the loss will really be noticeable. As for your MPG loss I can't say because I have a 6.5" lift not the 2.5" level, I did however drop down to 17-19 mpg on the highway from 22-24.
Sent from my iPad using Tapatalk HD
Thanks man that helps.
Thanks for the reply that helps
Just regear and tune you'll be fine lol. My buddies 09 just got regear'd to 4:11. Though the tune is what's doing it. He Managed 18mpg from Tallahassee FL to MS with 295/70/17 toyo mts. I managed 16mpg when I went to Tallahassee with stock everything.
Edited by 5RWill
Fuel "Rampage" 20"x12" (-44offset) wrapped in Toyo Open Country M/T 33x12.5R20
Your truck looks amazing with the combo you picked!
Thanks, I absolutely love the way these wheels look with the Brownstone color!
Stock gmc 18 on 35x12.5 bf
Need some more details! Lift? No hub knuckle rub with stock rims? Metric size or 35x12.50r18?
Edited by bcbz71
zone 3.5 inch combo 2 inch level 1.5 inch body lift rims motto metal 20x10 -24mm tires 305 55 20 nitro terra grappler g2 not shown but are installed now. i had to get new tire these in the picture are atturo trail blade XT's they are crap tires. they where unbalanceable. i had to send them back. i will take more pictures after i wash it. it sits level and i love it.
Edited by Chris the navy mech
Looks great! Ive heard Aturos were garbage. My local truck accessories shop says they too have issues with balancing. The owner said they were almost square when they come in lol
thanks man. yeah they were terrible.I tried to have them road force balanced and the machine said i need 96 lbs on one tire and 76 lbs, 43lbs, 39lbs on the other ones.
I've got a 2014 Silverado Z71 LTZ. Added the Rough Country 2.5" leveling kit, 20x9" Rockstar II wheels with a -12 offset, and 295/55 Toyo Open Counry M/T tires. Rubs a little at full lock right now, especially in reverse. I have aftermarket bumpers coming that should fix most of it, and will need to do a little trimming for the rubbing while in reverse. I'll try to take pics of the rubbing/trimming when I get some time. For now, here's a few pics of it in the shop (all I got for now) as well as some pics to show how much it sticks out with my setup.
Enjoy!
Edited by iversun
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
    • I may be old school. But I’ll pass. I’ll stick with the old stuff. Thank you.
