So... the 305/55 would be wider of a tire (sticking out a bit more) compared to a 275/65 tire which would fill "up" the wheel well more. Is that correct?
Sent from my iPhone
Correct, but 305/55 is still a decently tall tire. A 275/65 kinda has the pizza cutter look, narrow and tall
Sent from my treestand using Tapatalk
Edited by MOhunter92
Looking at going with terra grappler 305/60R18 with 18x9 fuels with either -12 or +1 offset. I have a 2" level, anyone running something similar? I'd rather -12 but concerned about rub.
Edited by spencerbureau
You will likely rub on a -12 but probably could get away with the zip tie method. 285 65 18 on -12 fuels has minor rub full lock in reverse with a 2.5" level. -6 offset racelines cleared with same tire same level. tires are Toyo AT II .
Recently got the opportunity to hook up with MRR Wheels and got a chance to try out their newest wheel. Been waiting since July to get them,definitely worth the wait [emoji1417]
MRR T228
22x10 ET30
305/40/22
4/7 Drop
  • Like 9
MRR T228
22x10 ET30
305/40/22
4/7 Drop
Those are SWEEEET
Does anyone know when discount tire does their $100 off with $400 over purchase? Ive noticed a few of you guys have done it. And im so ready to buy wheels and tires but id like to wait on that sale.
Sent from my SM-G935P using Tapatalk
I did all the common stuff, road force balance and even new wheels and tire but still never got it to go away. Even had a engineer look at it and tell me it was normal. I went to the dealer to trade it in on a 13 f150 but ended up getting another 14 but a Sierra this time. The Sierra is much better but at times a vibration for the first few miles but it always goes away, some days it's worse than others and some days it's like it's not even there. I would swear it's the tires from sitting but doesn't explain why some days are different than others and some days it's gone in a mile and some days it takes 4 miles. I could swear it's getting better with more miles on the truck and seems like I don't notice it more often than I do lately. Overall much, much better than the Silverado was.
I'm do for new tires before winter so I'm almost nervous about it because of how nice it rides now.
Funny looking back when I posted that, I was afraid I was going to get jump on for posting that thread being so new to the forum. I didn't think people would believe me! I still get updates emailed to me daily on that topic but I only read them from time to time, still seems like no fix for most.
Here's my new setup, moto metal 0970 +18 with my old 275/70r18 bfg ko2's
1BE25331-E5ED-42A8-B115-D8819061A442-149
I really wish they made these in a 0 offset, anyone have any info on some good spacers that may push these out to about what a 0 offset would be?
So I installed the RBP Glock wheels today, and I think I am in love! 20x10 (-12 Offset) with 305/55R/20 Toyo AT on a 2.5" RC level (stock rear blocks). I did rub on some plastic a bit but I trimmed it and now I only rub on the liner ever so slightly.
Before Level:
Tires / Level:
99ae778432280124a80530e9f959edcd.jpg2da76380377181048619a78dfab2a4ae.jpg1c9621f02fd1d880f5f978595b1a7e23.jpg8761402e4d1b974bd48bfce230ac1ec2.jpgf2205778fba173e6336664f95247189f.jpg
Edited by Wazbe
  • Like 4
18x10 -24mm Moto Metal Link MO977 "Blackout"
BFG K02 35x12.5r18
McGauphy's SS 7-9" lift
Deaver Rear Springs (plus a 1" block for forward rake)
Measures 47" in the back, 46" up front. Rides excellent.
MPG's about 15 highway, 10'ish in town. (5.3 v8, 3.42 gears)
Trimmed the valance 1/2" at the bottom, diagonally up to where it meets the bumper as it rubbed slightly.
  • Like 6
BFG K02 35x12.5r18
Looks mean man!
i have a 3" motofab kit with 2" bora wheel spacers and 34" toyo open country's, on my 2015 elevation edition. been 7500 ish miles on all of it and my driver side ball joint has a ton of play !!!! anyone run into this yet ? also any opinions on a budget friendly upper control arm to fix the ball joint angle ???
14593598_1045223108930399_225991850_n_zp
14502977_1043467605772616_54720992600565
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
    • You got a 4 legged walker or a 4 wheel rollater?
    • Does lowering the truck change its towing capacity?  I wouldn't mind lowering mine, but I loan it out a few times during the summer for my daughter to pull her travel trailer (5,000lbs).
