Thanks! I have not, just back and forth to work since installing and taking to the shop to verify my alignment. Have a couple finishing touches to get done over the weekend. They ride amazing though! A nice firm controlled ride that soaks up big bumps, driveway lips, and speed bumps like they are nothing. No more float and bounce like stock. I could literally drive over my driveway lip at 30mph with an open cup in the cup holder and not spill a thing. Crazy.
Looks like you cranked them to 2.5" or greater?
That SDHQ skid plate looks great. I really want one but I would still need to mount my front license plate to it and I'm not sure if it would look good like that.
Sent from my SAMSUNG-SM-G920A using Tapatalk
That's a bummer with the front plate. This thing fit absolutely perfect, SDHQ did a great job with this. I'm with you though, not sure it would look right with a front plate.
Truck is BAD. I dig it! Really wishing i could go snag me some Kings for mine. Going for wheels first though
Thanks! No regrets, 100% would spend the money again to do it just like this. The Kings ride like their price tag, worth every penny so far and I haven't even worked them yet.
Edited by 89stroker
This is basically how the 3.0's came right out of the box. I ended up adding 1 full turn for CV axle to shock clearance (since the adjusters are on the bottom on the 3.0's) and the height turned out great. Instructions said something crazy like 2.5 or 3 turns = 1" ride height change so I didn't do much with my single turn.
Nice.
Good to know!
This is my 2014 RCSB 2wd. Lowered in front with 2" BellTech Spindles, rear is 2" BellTech Shackles and the block removed, about 3" total.
20x8.5" Black Rhino Pondora wheels with 18mm offset. 275/55-20 GoodYear Eagles. Rubs a little bit in reverse, I expected it though. Kind of want to drop it just a little more to get rid of the rake but don't know how to other than removing the helper leaf spring.
First is a before shot of the day I picked it up used last year:
Second shot is as it sits today after the new wheels and removing the stripe kit, debadge, and tinting it.
Edited by Ian-NH
2016 Silverado with 20x9 +18 Gear Alloy Big Block. 295/55/20 Toyo AT2 extreme. 2" RC Level. No Rub.
Love the truck! I have a 2017 just like it. I am wanting to do the same rim size offset and tire size. I like that your wheels are still tucked into the fender well. Your signature says you have a 1.5in body lift, was that done after these pictures? Did you have to do any trimming to clear that setup when you had just 2" RC? Any complaints with the setup and the 2" RC?
Thank you,
Thank you,
Thanks. No trimming needed with this set-up. My only complaint has been the drop in mileage due to the weight of the tires. I still get 16/18 mpg and I would definitely do it again.
Here's a pic with the added body lift.
A close up of the Wheel/Tire combo
  • Like 5
Done right man! Can't wait to hear the update after you do some wheelin'!
Sent from my Nexus 6 using Tapatalk
I'm debating between a 285/45/22 tire/wheel combo. Or a 33x12.5x20 setup. Anyone running a factory replica 22" wheel? If so how are they quality wise?
Got bored today and hit the farm and CRP for a bit, to see how the RTs handle some Mississippi gumbo. This is coming from street tires so there is a noticeable difference in traction already offroad. In the buckshot heavy clay stuff, you gotta keep em spinning, which i figured as much. Though they do clean out quicker than i thought they would. Also to add for you guys going with 0 offset if you get in mud you're going to want to invest in fender flares with a tire that 11.5" wide or larger. I've got mud on top of my truck, in the bed of my truck, and of course all on the outside. On the CRP with a little more defined bottom i went all the way back on our place in 2wd. This is all at 35psi so driving range for me. If i had a pump i'd air down to 20 just to see the effects.
It looks like you drove through a field of cow dung!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
