Why did you choose gm-trucks forum
02suburbanZ71
I chose this forum because the people seemed the friendliest and i loved the emoticons and faces you can choose from. What attracted you to this site opposed to other gm forums?
  • Replies 60
Because back in late 1998 prior to the gmt800's being released there was no other truck forums. I can say I was one of the original first 10 members
Ryan
Back in 06 when i googled info for my 89 s-dime this was were a majority of the info was
Same as Chris, had all the info I needed for my truck and was the first forum to pop up in my search.
Same as Ryan, I used Edmunds.com for a while but it was hard to use and you had to read a lot of bs to find out anything. :jester:
The people here are normal compared to any other the other big ones.. GMFS and FSC are terrible IMO
Yep. Same reason why I'm here.
The fights over there were priceless. I stayed on there for those. Do you remember Tim he had a 2500LD? He finally loved up to a gmt900 2500HD
Ryan
The only other truck forum that wasn't platform specific I used was GMFS and most of the people on there just rather talk sh*t, act like they're better than you for knowing more than you or be sarcastic without helping. They also sometimes like to gang up on you. The only other truck forum I used was GMT400 when I had my 98, but I wasn't that active on there. It was good when you want to ask something that's GMT400 platform specific.
The people on here seem to be more friendly and rather help than talk down to you. It's not that I have thin skin, but dealing with most of the people on GMFS is just annoying. After finding this forum I don't even look at GMFS anymore. I was never as active on GMFS as I have been on here. Also I'm very opinionated, but I usually know how to give my opinion the right way where as on GMFS they do it in a way that makes them sound like a douche.
I met Zane back in like 2005 I think at a ZR2 group meet/dinner and I had just gotten my 2003 Silverado. I wasn't as into the forum thing back then so I poked around some back then but never joined but then after straying some with a Tacoma and turbocharged Subaru I began looking at Silverados and came back here.
I'd say this is the most balanced of the various forums, which keeps me around for the most part. GMFS, my number 2 site, is full of silliness, but I can honestly say I've never been a target over there, although I've received criticism about my truck. I've probably only got a 1,000 posts over there vs. my post count here if that says anything.
In all honesty I think I found this place when researching something for my truck. I was also at another truck but it had very little traffic and it was borderline dead, I think I only had a handful of posts.
This is by far the best truck forum I've encountered, no real complaints thus far.
    • Okay Punch What year is your truck or did you already mention that ? Can you link the TSB is about that noise ?
    • Thrust bearing is a very small window.  But nice try.   Turbo oil filter?  Haven't seen any failures.  Change your oil more frequently.  Use a better oil than the factory oil.
    • There is a p/n called out in the one PI that GM has.  Curt 57003 inline load adapter that is used for LED trailers that are having trouble with these newer trucks.  No cutting, no splicing, etc.  GM did update the lighting module around 2023 to better pick up trailers with LED lighting, but it still can happen.     Here's the link to the Curt site for it - 7-Way RV Blade LED Electrical Adapter (Not a Wiring Extension) SKU #57003 by CURT   The PI I am referencing - MC-10208985-9999.pdf   Its not just a GM deal either.  Newer Fords and Rams have this same problem.       In another PI, they recommend that the trailer has a Pollock brand 7 way on it as that is who makes the truck sides for the OEMs.  GM is also big on making sure the trailer is trouble free.  So no wiring issues, all lights are functional, better quality 7 way plug, etc.     The other PI I am referencing - MC-10178359-9999.pdf   The model year range is older but it is the current PI for 2014-2026.  It calls out the Pollock RV HD 7 way they recommend.
    • That's part of the problem...the EGR has already been replaced, and I've already had the complete intake assembly removed, and the EGR passages were clear at that time. That leaves wiring, PCM, or another variable that I wasn't expecting. Best I can tell, it's not wiring or the PCM, so I'm grasping for straws.   The PCM uses the MAP reading to confirm the requisite loss of vacuum in the manifold when the EGR activates. Since that's vacuum related, it involves a lot of other systems which could play a role.   The overall diagnosis has to be considered too. The fuel lines in the intake had rubbed through and were dumping fuel into the intake, drowning the cylinders in fuel, and putting raw fuel into the sump and cat converter. The fuel system has been fixed but the complete path of damage may not be. If the cat was damaged and melted the internals, it could be partially obstructed and also playing into the EGR issue.   I'm retracing my steps; trying to go back to thinking thinking Horses not Zebras based on the clues I've been given. These engines aren't *that* complex.   Could it be, now that the truck is running well, that carbon and crud from being run with the fuel system in disarray is now dislodging and clogged my clean EGR passages where I can't see?  That's what the code is actually saying. The flow is restricted, dummy. Retrace step 1.   I may just need to remove the lower intake again. Before I do that I'm going to try removing the EGR and running the engine for a few seconds to see if it will blow anything lodged in the egr passages out through the open ports.     That's been helpful in the past. For the spider injector, there's no guarantee I'll get a working one. The spider I have seems fine now that the high pressure fuel line isn't making an early delivery via large hole. SO at least I'm not marooned and looking for one of those.   Row52 (dot com) is also a good one for watching for vehicles at local yards.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
