That sounds well beyond my skill & patience level, thanks for letting me know.
Sent using Tapatalk - 2014 5.3 WT
If you do the disassembly, you can have the grille surround and the headlight frames color match  painted pretty reasonably. That is what I did. Since my truck isn’t black, I also had my Rockstar II wheel trim and center cap star match painted as well.
- the chrome center star is available from KMC (RockStar) for $3.56 each IIRC. Your tire shop may have them on hand.
2018 LTZ Silverado.  Finally got it cleaned up a bit after the New England winter.
5cc4d0a69b423_truckrear.thumb.jpg.03f64af15d16f391ecc41a52c1689152.jpg5cc4d0eab2715_trucktireandwheel.thumb.jpg.8378cc17a615c5d45cb38fa7a70b6f50.jpg
Edited by outrag1
Birthday present to myself. 4” BDS lift and 275/65 R20 Goodyear Duratracs on my stick rims. No rubbing. Added rear spacers to even the trackIMG_0378.jpgIMG_0379.jpg
On 5/6/2019 at 2:56 PM, Kurtj29 said:
New black front end.
Stunning!!
On 3/1/2019 at 12:58 AM, DHaze83 said:
Bowties look good - are they plastic dip or painted ( RED )  ???
Custom painted.
Rivercitycreations.com
4 hours ago, DHaze83 said:
Custom painted.
Thank You
    Frank V
    Frank V
  • Who's Online   6 Members, 0 Anonymous, 1,043 Guests (See full list)
