I have been thinking of putting lowering shackles on mine to try and even the rake. Would either of these shocks be good for this. I would like to take some of the bite out of the Z60 harshness. Sprinkle GSM in front would really probably help. I am 2wd and extended cab.
I just got the 5100 installed with roughcountry 2.5 front and 2 rear. All I got to say is that my ride is smooth as butter. Way better than stock! And that's with 20x10 -12 w/305 55 20
I have the same level kit and am thinking about the 5100's. Any fitment issues or anything I need to be aware of?
Thanks
Thanks
I am also considering this set-up. I believe I would run just the 2" below strut spacer and 5100's on 2nd setting (1 up from stock).
Thank you for the continued orders!!
We are stocked up on 5100s, get yours here - http://shop.mrtmotorsports.net/bilstein-shock-sets/bilstein-5100-complete-set/2423830433238319/i-2304103.aspx
Do you have the NHT Heavy Tow package?
Yellow/Blue = 4600
Silver/Black = 5100
Both a big upgrade over the stock shocks. Go with the 4600 if you want to keep stock height or are needing maximum control for towing or want to run a leveling spacer. Go with the 5100 if you want to level the truck without a spacer or if you like to go offroad.
I'm pretty sure we talked about this many pages ago in this thread so forgive me for maybe asking again. I have a '15 Sierra Max Tow. I'm not happy with the stock ride quality, would like to raise the front some but not too much because I tow and don't want the front aiming too high with a trailer attached. Would you use 5100s in the front and 4600s in the rear? 4600s all around with a spacer in the front? Thanks.
Edited by Red_5
5100s all around!
We almost always suggest the 5100 over the 4600, unless the end user is really wanting to use large front lift spacers (The 4600 is slightly shorter and works better with the spacers, you dont want to be stacking lifts).
For the last 4 posters, the 5100 would be the optimum shock. The only thing to be aware of is to not run the 5100s on the top setting with spacers, you are asking for trouble doing that.
Get them here - http://shop.mrtmotorsports.net/bilstein-shock-sets/bilstein-5100-complete-set/2423830433238319/i-2304103.aspx
5100s all around!
I have read through this forum and the 2014+ Leveling Kit forum over the past 2 weeks (surprised it didn't take me longer) and have gathered some great information. I am looking to only have a maximum of 1/2" of rack when it is all said and done. I have and the puck style level on previous trucks and the ride has been terrible. I am looking to try a different route this go around. Do you think 5100's on 2nd setting and a 1.5" - 2" bottom spacer would would create any major problems, and should it ride better than a 2.5" RC level on stock struts? I am aware of the additional wear that comes along with a 2.5"+ level but I am hoping the Bilstein 5100 will reduce that.
It should ride better than the 2.5RC on stock struts yes. We havent not tested that setup, but I know some other members who are running that who have not had any issues. It may be a little on the firm side with that much preload, but I dont see any issues other than the extra stress on the stock upper ball joint being at a 2.5" lift height.
Floaty in the front and planted in the back.
Sent from my SM-G930P using Tapatalk
Just installed 5100's in all corners. I don't have a spring compressor so I had a local shop install the front's. When I got home I noticed this gap by the upper spring seat. Any suggestions on a way to rotate it into place without removing and compressing the spring? I'm sure it's probably unnecessary but I'm a little ocd and I know this will bother me until I fix it (next time I buy a compressor and do it myself from the start).
Do you have any pics of the final look? I have some KO2 275/70 on stock 18s and have bought the 5100's for all for corners as well. Just haven't had the time to put them in. I'm debating on using the middle setting BBC I've seen on here that the truck might ride better, but I'm sure the highest setting will work fine.
How's about a discount for some rear 4600's since my pic was used on your website for the rigid fogs.
Yes totally! We never set up much of a discount because we sell 5100s 20 to 1.
Only issue, I dont have the rears in stock. I do have 6 fronts ready to rock. Shoot me a PM and we can discuss :)
Hard to get a good pic, very steep driveway. If I'm out today I'll get a side profile. Lowest setting in back, third up setting in front. Looks level to the naked eye. Measures out to be in inch lower in the front. These shocks eliminated a ton of the body roll and got rid of the bobble head effect going over small bumps at odd angles. The ride was stiffer at first but after 5k miles it's a softer ride than when I came off the lot.
Edited by Mp87
Better profile pictures, still has the small 255/70 stock tires. The 275/70 18s will look nice.post-167364-0-21622700-1490537819_thumb.jpgpost-167364-0-29696600-1490537828_thumb.jpg
Better profile pictures, still has the small 255/70 stock tires. The 275/70 18s will look nice.attachicon.gifIMG_20170326_100301.jpgattachicon.gifIMG_20170326_100326.jpg
Looks good. I bought my tires right before our ski Tripp to NM and didn't even get to play with them on. No snow until after we left. This is about all I got to do. 8bae8badf595b4c2afcc3f7b9e587cc8.jpg
Edited by TeamGoose
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,086 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
