On ‎8‎/‎23‎/‎2018 at 1:34 PM, jpmiami said:
so it would seat higher than the 2.5 the RC kit gives me? my truck has 75k miles on that kit and rides well. Just want a firmer better handling ride.
First, let me say I don't know with certainty what might happen if you "stack" two "lifting" methods--in this case an RC 2.5 spacer type lift combined with setting the Bilstein 5100 on its highest setting (1.85" lift on our trucks).  I think it would lift the front end higher by a certain amount.  If you are happy with your current front end height, you could get the 5100s but set them on the "stock" height setting choice rather than one of the "lift" settings--there are four setting choices on the front Bilstein 5100 struts.  Or, you could get Bilstein 4600s all around which are stock strut/shock replacements that don't alter "lift."  I have never owned the 4600s but when I was researching all this lift stuff, guys seem to say they are fantastic and a good value.
On ‎8‎/‎25‎/‎2018 at 8:45 AM, Sierra Dan said:
A little something found on the leveling thread Homeslice......
I wanted to correct a typo in my early writeup saying GM has "KBs".  I meant to say GM has "TSBs" and "PITs" that tell their service advisors and mechanics what to look for when a vehicle is altered and how a warranty might be impacted.  In this case, "TSB 09-00-89-016E" and "PIT 5403B" were the two documents I found that were relevant back when I looked into this matter.  They may have newer ones now.
On 8/25/2018 at 4:52 PM, Roscopcoletrain said:
Is the 4600 still recommended over the 5100 on a stock height truck for towing more often?
4600 and 5100 are identical other than one is painted yellow, one is silver.
5100 has a longer profile for extra lift vehicles.
You can use 5100s on stock height if you prefer the silver look over the yellow.
You may be able to manage it with that combo. But anything more than 2.5in of lift will really mess up some parts.
If you just want a better ride yet already have spacers. I'd check out the 4600s or use the 5100s at stock height.
I just want to be at 2.5 like now just without bottom 2" rc spacer.. thinking 1.85 from the 6100 plus the .25 Rc top strut spacer and see how it looks.
On 8/18/2018 at 9:49 AM, 2009GMC said:
285/70/17 bfg k02
5100 on 3rd setting for 1.5” front lift. Rear stock block. Still have 1 - 1.5” of rake which I like for hooking up trailer or small load in back.
I have about 250 - 300 lbs of tires and bed cover in pic.
Do you have any issues with the tires rubbing the upper control arm or fender well?
No rubbing.
Since my tuck is max tow I have steel upper and lower control arms.
The 17" GMT900 wheels are at least an 1" narrower than stock K2XX wheels, offset may also be different.
Upgrading the Factory Rancho Shocks on a 3/4 ton 2015 Sierra. I don't see much as far as the class of vehicle listed on these changes are the shocks the same on a 1500 as a 2500? If I were to put bilstein's on a 3/4 ton what model would I be using? I have not researched this much I'm just watching the thread a little bit with some basic little questions. Thank you in advance for any response
I've read through as much of this thread as I can but I'm sure I missed this somewhere.  I'm having some installed as we speak and I asked them to leave it on the lowest for stock height.  I actually like the rake and don't care to level it out.  After I get through a hunting season and figure out if I want some lift I may move them up a notch or two for clearance.
How many people are running the 5100's on their lowest setting?  If you did, did you end up raising it later?
I just traded in my 2015 for this 2018. On my 15 I leveled the rear but on this one I want to level the front. My first choice was to do it using a spacer but I think I've decided to go with the Bilstein shocks instead. Where is the best place to buy them from? Would I be able to do just the fronts and the the rears later and how hard is the install? I've done suspension work on my Camaro but never on a truck, especially not a 4x4. Thanks
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
