1 hour ago, jgraves13 said:
I wouldn't run this if I were you. just a huge spacer. You'll kill your lower balljoints quickly and the ride will be less than desirable because you won't have any down travel and will hit the arm droop stops every time you hit a bump. Take a look at the zone 4" lift instead
Really?  It looks like it replaces the UCAs and it drops the diff, which I assume would put the drive shafts at a better angle... Maybe the other part that they replace in addition to the lift kit are the ball joints?
They warranty their stuff, so if this was a problem I assume they would want to avoid that?  I will ask them.
These guys said they have good luck with them, and combining them with the 5100's they said really makes for a nice ride.  I should be able to step up another size in tire as well.  It's got a 285/65r18 on it now, I might be able to squeeze in 1 size taller.  That's about it for this truck, they say to get 35's you need a bigger lift and to probably trim fenders and stuff.  I won't go that far...
Maybe they will warranty, I'm not sure. Beefing up the balljoints only helps to an extent, if the angles are shit, the angles are shit. Doesn't matter if it's a big balljoint or a small one.
As far as ride, maybe it rides okay. But it definitely won't ride as good as a kit where your arms aren't overextended and riding on the droop stops at ride height.
Some care, some don't. Really up to you, just giving you my opinion and I know some others on this forum and silveradosierra.com would agree
What wheels and tires do you have now? I was looking at those upper control arms and found out that you have to run wheels with a certain back spacing to work with those control arms. I ended up going with cognito control arms
Still a work in progress.  So far I just added a JL Audio 250W amp and 8" sub under the back seat, had the dealer install a 2.25" front level kit and 3" lift in the rear to keep a little factory rake, upgraded the tires, plugged in the box to disable AFM and force it to 8cyl mode all the time(Range Box), removed the muffler, exhaust flapper and resonator and had a shop weld in SS piping, and then added a chrome exhaust tip from an Escalade... so straight pipe from the cats back, sounds great.
I removed the lower air dam and side steps for more clearance, and then yesterday removed the entire black plastic lower bumper and chrome mustache, and on Friday I am having a double row of "black chrome" light bar installed in the gap created between the rescue hooks...  Oh, and I took out the crappy plastic skid plates and installed the heavy aluminum ones from GM, the cover the front and the oil pan... transfer case already had steel plate protecting it...
I will take nice pics on Sat, after the light bar system is installed.
46 minutes ago, SquireSCA said:
Stock wheels, with Ridgegrappler 285/65/r18 on them
Found this on their website. I would call and confirm with them about wheel figment before ordering the kit if you do decided to pull the trigger.  This is their leveling/control arm combo kit but it uses the same control arms.
Gentlemen,
                I've read about 4 pages and realized there is just way too much on here to read it all. I'm a little confused, I have a 2018 1500 Z71 midnight edition. I'd like to fit 33's, so I was going to level my truck using one of the kits online. From what I gather, its possible to do this using the Bilstein adjustable 5100's? Where is everyone buying these?
Cliffs anyone? Sorry for the laziness but 112 pages man, holy hell.
FZ71 Skywalker post...
i understand - when faced with too many choices we tend to “not choose!”
Here is our three week old Sierra 1500 SLT
My GOALS:
- Custom wheels to improve appearance.
- Maintain or Improve factory ride comfort.
- A simple “proven” and effective lift solution which was a reasonable cost.much.
- Crowd Favorite ...something the majority of reviewers agreed was a great upgrade.
- Must Have is a snow rated a/t tire for our mountain passes here in Oregon or Jackson Wyoming.
Simple:
I just didn’t want a hassle, or multiple shop visits. So a plug-n-play solution
Here’s what I did:
20” x 9” Fuel wheels to help fill the fender wells and dress up (a plain looking) truck. Very conservative custom look.
275x65x20 BFG KO2 tires
quiet, good ride, proven respected tire with a snowflake symbol (indicating snow rated)
Cost wheels and tires:
(Discount Tire - $2185 with rebate coupons)
Bilstein 5100 (adjustable front) shocks
(height set one click from the top setting) set of four shocks $345 + install cost
Result:
*Better Ride
*Improved Handling
*Taller stance
*Customized appearance
Am super happy with end result.
This is is a temporary truck for me. I will drive 12 months and donate to my daughter ...
Note:
this is a 2018 SLT Sierra 1500 with a “Denali-look” grill installed by dealer and front bumper vinyl wrapped (in black) $300 for wrap
i hope hope this helps somebody :) who’s looking for ideas. This is about as simple and conservative + proven as you can get.
Would love to have Terra’s on there, with their amazing look (trail?)... have owned them before and loved the look! But I need a highway distance “ride” for those occasional 7 hour+ drive/days.”
note: actual final stance is a slight rake with rear higher. This stance appears level, but actual truck stance is slightly lifted in rear.
Result: quiet riding BFG’s, better ride overall with 5100’s and a “snow rated” year round A/T tire
Smiles
Stock setup awaiting Discount Tire install
Edited by Oregon_GMC1500
Additional image:
whoops!!!!
Forgot to mention slight rubbing when full turn in backing up.
5600E5B6-B9F1-4583-BC50-2887253B011D.thumb.jpeg.78a2943101019dff4f91cfb736c190a3.jpegMinor trimming solved the problem. 275x60 would prob have fit without rubbing. But I was looking for the highest sidewall possible without a lift. And I didn’t want the leveling-kit option because of reports of diminished ride quality with leveling kits.
3rd height setting and stock rear with 275/60/r20 Duratracs.
I had to trim my factory mudflaps on the insides just a bit.
I added 5100's this week. 3rd setting. Also 275/60r20 cooper AT3 4s tires. Like the setup.  Much better ride and handling compared to the stock Ranchos.
I have almost and identical set up to you except I'm running the Cooper 275 70 r18 and I'm curious if you like the handling I just adjusted my bilsteins from the second to the bottom to the 3rd setting and driving to Houston yesterday I found myself getting carsick from the constant vibration it just seems like setting to is too soft and there's not enough rebound in setting 3 it is a brutal ride
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
