When I installed my 5100s on the highest setting my toe was all out of wack.  I later installed a 1/4" spacer under the strut to get a little more lift and tow changed again but it was barley outside the factory range.  I got it aligned to bring it back within spec.
On 2/28/2019 at 11:12 PM, Yondu said:
They have been coming soon for 5 years.  We have had a part number for like 6 months, IIRC.  I called Bilstein a few days ago and they said very soon.
Minds will be blown if/when they actually come out
Did Bilstein offer any specifics or did they just say "very soon"?
On ‎2‎/‎28‎/‎2019 at 9:05 PM, bhales said:
so what am i missing about this part number for the 6112:D:smash:other than the fact no one seems to have ever had them instock. i went over some railroad tracks today and i thought i was gonna die the ranchos SUCK.
Ahhh, the infamous Bilstein 6112 shocks for our 2014 and up K2's
You will have better luck trapping a Sasquatch or sitting down to dinner with an Alien !
Most of us gave up on the 6112's years ago since their first reported introduction back in 2015.
Yes, Ranchos SUCK on railroad crossings and potholes.
Funny thing is, the 6112's are currently in stock for 2015 and up Tahoes and Yukons.
Many wonder if you can just order a set for the Tahoe/ Yukon and bolt them up to our K2s......
The GM parts sites list Silverado, Sierra, Tahoe, Yukon as fitment for the same spring & strut part numbers so wouldn't aftermarket be the same situation?
Sent from my Moto Z2 Play using Tapatalk
When I pressed for more information he said should be within the next few months, keep checking our site.
I'm not sure what the difference is between the Tahoe Yukon and Silverado Sierra are. It's very interesting they would release the SUV parts first as I would think there's more of a demand for the trucks.
At the price the Tahoe / Yukon 6112s are I would have expected a threaded body for adjustment on the truck & a decent top mount, not re-using the stock rubber stuff.
If you want threaded adjustment you are going to have to tap into the Coil-Over market and pay nearly double.
The point was, the aren't being used as a stopper, it's already sitting on them.
Going back to this bump stop situation, did you find anything else in this regard?
I had about 2" of travel showing between the shock & bump stop when it was assembled but no weight on it. I don't know how much the truck compresses this but I doubt there is much stroke left before the bump stop is contacted.
This might be part of the problem with the OEM shocks, allowing the suspension to bottom out easily & bounce off the bump stops.
I will try to see if I can check the gap to bump stop with the truck on the ground.
Ok, after typing the above, curiosity got the better of me. I cannot get the dust boot out of the way enough for a photo but it absolutely feels like the bump stop is sitting on top of the shock body & I can't move it up with my fingers.
Next step will be to take the weight off & see how much the suspension compresses with the truck weight.
If this setup really is allowing the bump stop to be partially compressed most of the time that seems very strange.
Mine is the same way.  I can't imagine it's any different stock, but I never checked.
Does this all suggest that they would ride better at 2nd or 3rd height setting rather than the first?
Mine is at 2nd stop, but yes that would make sense.
My guess is stock shock is most likely worse as it has softer damping so compressing bump stop more when hitting a bump in the road.
I'm at 1.4 lift, 2nd to top.  I assume the truck would ride after if the bump stop were trimmed.
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
