On 8/1/2019 at 12:35 PM, Yondu said:
These trucks, especially the 16+ with their higher hood look nose high when "level".
I put a 2" block in for a .75" rear lift when I lifted the front 1.25".  Trucks look best with a rake, especially if you want to use it as a truck. Level trucks look frumpy like they have worn out springs!
Totally disagree.
40 minutes ago, Slash L86 said:
Stock wheels? What's the backspacing?
Double check before putting on those camburg uca. Think the minimal amount is around 5" or so. Maybe little less is ok. Believe camburg recommends 0 offset wheels. Which is exactly what I have. Heck my stock uca had a slight rub from my stock 20's. I like the slightly aggressive look with the 0 offset as well. Pokes out about an 1- 1.5 with the cooper at3 xlt 285/65 18.
Wheels are black rhino Mozambique.
Good luck.
Another thing. I have the 6112 at max and also 1" shackle lift on the rear and they look same height. Maybe that's just cause my driveway is sloped? I'll check on flat ground today. Thought it should have at least 1" rake. No worries as I rarely tow or haul around anything atm. If I do more towing I might add bags or active suspension.
I know pics. I'll try to pop some up later.
I got the call this am that mine will be pushed back till next Friday. I'm close with the owner and told him that if shit came up, NBD. Not happy but what can I do? I have too much on my plate as it is and don't feel like being that guy.
I have the stock All Terrain 20's and they should clear the UCA without issue. I read that note on their website and went out and looked before ordering.
I also rarely tow but will be installing the Firestone kit this fall. The horse trailer barely makes her squat. Its the feed and fertilizer but that is one trip in the spring and once in the fall.
My truck has a decent rake from the factory which I hate. I' at about a 3" rake right now on stock equipment. 2014 GMC AT extended cab with 89,000 on the clock. I'm going to see how it turns out and then go from there.
1 hour ago, 4weight said:
Totally disagree.
That's okay man, I'llcringe every time I see a leveled truck and you'll cringe every time you see one with rake. I did tow my car and trailer last month and it was level.
If you have the same exact wheel gap front and back they look very nose high o me. My truck had 2.25 in of rake when I bought it, I've heard others have far more rake stock up
Edit. It looks like your truck is a GMC. 16 + Silverados got a new hood that sits higher than the 14-15s
Edited by Yondu
You aren't the only one, most people say the same thing when the truck sits dead level regardless of the hood, they all look like they have that Cali lean. Never understood all the desire to sit level, it pretty much just announces you didn't buy a truck to use it. Anytime you put some weight in the bed or on the hitch when level it handles worse than it should, which is even more dangerous on the road in an emergency situation since the more the rear goes down the lighter the front end gets...
Tyler
Edited by amxguy1970
6112 max height, 5100, maxtrac shackle 1" lift
6112 specs say 1.85" but believe closer to 2-2 1/4 cause the shackle raised exactly 1" (while front had 2" pro comp spacers)and rake was 2.25 before mods. Now 1-1.25
2018 6.2 nht
As far as what looks/performs best everyone has their own options. Plus, it's their truck.
Personally wouldn't mind dead level or 2" rake.
Thought both looked ok. Just a tad much either way.
Glad mine came out where it is.
Good luck with your builds.
Edited by Slash L86
No worries man.  We all like different looks for sure.
Little better perspective. Recommend 1" rear lift if going for max height 6112. Believe shackle is preferred over block?
If not lifting rear next highest setting would probably be best. As stated earlier to each their own. I like a slight rake myself...
What's funny is if you load it up or tow it will sit level or cali lean at factory rake heights.
So, if you level it and aren't hauling anything it's the same.
Maybe very good case for bags I guess?
Edited by Slash L86
Hey Ya'll, new to the forum, not new to GM trucks. 2017 Silverado 2500HD Z71 double cab, 1 size over stock tires, stock ride height, 29k on the clock. I just put a set of 5100's on after much research. The rancho's were toast. Smoothed out the ride, much better and I should have done it sooner and will do it again! If you are on the fence, best $350 bucks one could spend. And strangely enough, my gas mileage jumped up by about 2 MPG.
One question I have on 5100 shocks, front & rear...can you put them on a stock truck without lifting? 2015i 2500 HD Z71 GMC
Stock tires/Rims.
Sierra Boy
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
